20 Most Recent Schlage Electronic Lock FE595 Plymouth or Camelot series Questions & Answers
Schlage FE595 keypad replacement part
Your best bet is to contact Schlage directly. You can call during Midwest business hours (Mon.-Sat 7-7) at this number:Warranty & Technical Information 1-888-805-9837.For further information for the FE595 (installation & programming manuals and videos), go to this page:http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspxThe manuals are PDF files. If you cannot open them for viewing, you need to first download & install Adobe Reader, which you can get here:http://get.adobe.com/reader/Good luck!
1/28/2019 7:08:43 PM • Schlage... • Answered on Jan 28, 2019
Exploded view of parts for fe595 schlage digital lock
If you haven't already found this out, parts are not available. Response from Schlage: Thank you for your e-mail. Unfortunately if he had these locks on his business there is nothing we can do as far as repair. And unfortunately there are no dealers who have the parts available for repair. These are strictly residential keypads. I am sorry about this. Joshua Bozarth Consumer Loyalty Representative Schlage Customer Commitment Center 2119 East Kansas City Road - Olathe, KS 66061
6/24/2014 6:31:17 PM • Schlage... • Answered on Jun 24, 2014
0answers
Base plate
Be the first to answer 8/23/2013 5:31:20 AM • Schlage... • Posted on Aug 23, 2013Be the first to answer
Will not lock
10/6/2012 9:49:18 PM • Schlage... • Answered on Oct 06, 2012
Fe 575 how do I change the battery? and code?
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry....
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video will be useful to allow you to disassemble it and view the sticker.
6/29/2011 3:11:02 AM • Schlage... • Answered on Jun 29, 2011
I lost the manual and i need to reprogram the
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
3/6/2011 12:23:04 AM • Schlage... • Answered on Mar 06, 2011
I need to change the
3/5/2011 11:42:56 PM • Schlage... • Answered on Mar 05, 2011
Printable instructions to change code on a schlage lock
Check out their guides here; https://www.schlage.com/en/home/faq.html?id=128844
10/22/2022 12:03:39 AM • Schlage Locks &... • Answered on Oct 22, 2022
2answers
Schlage Smart Lock - deadbolt unlocks then immediately locks after code is entered. Barely enough time to open door.
The battery pack may be weak. They are set to stay locked as opposed to stay unlocked in case of battery failure. Not being able to use the key is an issue in its own right. You would need a locksmith to solve that one. https://www.google.com/search?q=Schlage+Smartlock+change+battery ..
9/19/2022 8:33:45 AM • Schlage Locks &... • Answered on Sep 19, 2022
Schlage Electronic Lock. Unlock the door from the outside without the code or key?
Strange that an internal door has one of those! No, you will need a locksmith or some way to get in the room another way (window, cut a hole in drywall). Or you spring the door jambs apart and slip the lock. Sometimes you can remove the hinge pins. Or drill the key lock out with a Carbide Drill. It is a $95 lock. https://www.google.com/search?q=FE575 ..
7/11/2021 6:31:32 PM • Schlage Locks &... • Answered on Jul 11, 2021
I have a schlage be365 lock. Keypad works great but the key for manual overide wont go into slot. Checked and theres nothing foreign in the slot
Perhaps you were given the wrong key when you purchased the lock, it happens sometimes. If the lock is new take it back to where you got it from. Have it replace with another one, check that the key works before you leave. If not new a visit to a locksmith is the best bet. Regards Geoff
1/7/2020 9:31:07 AM • Schlage Locks &... • Answered on Jan 07, 2020
I have a Schlage FE595 Keypad Lever lock that needs the battery changed, but I cannot remove the cover after removing the screws.
There are two Philips head screws that hold the inside cover in place; a manual screwdriver is better than a power one. The screws are positioned close to the 12 and 6 o'clock (12-hour clock) positions around the lever handle. Thus the top screw is below the manual lock; there may be a cover partially hiding the fastener. The manual for the FE595 is available from Schlage here: https://www.schlage.com/content/dam/sch-us/documents/pdf/installation-manuals/23780042.pdf . Make sure to look at the picture for your lock since the manual covers at least three models of keypad locks. A better picture may be in the installation guide here: https://images.homedepot-static.com/catalog/pdfimages/cf/cfae64fe-e7be-4146-bc26-4803ec302d5e.pdf . Try carefully running a utility knife or other thin blade between the inside cover and the rest of the lock housing on the door. You may have some dirt sealing the two sections of plastic together. I hope this helps. Cindy Wells
1/4/2020 10:05:23 PM • Schlage Locks &... • Answered on Jan 04, 2020
I have a Schlage keyless entry pad on my front door. It was working fine, until it locked my roommate in the house. The thumb turn lock moves, but it will not engage the deadbolt. I have never heard of being locked in. Help.
Contact Schlage or a locksmith, assuming you don't have a key. Some models allow someone to replace a battery and reset it, but not known if yours is one. See Contact information. https://www.schlage.com/en/home/faq.html?id=128695 If you have any questions or need additional information, please contact us via phone at 888-805-9837 for the United States. Hours of operation: Monday - Friday 7:30 am to 5:30 pm (Central Time) Saturday 9:00 am to 3:00 pm (Central Time) If you have any questions or need additional information, please contact us via phone at 800-900-4734 for Canada. Hours of operation: Monday - Friday 8:00 am to 5.30 pm (Eastern Time)
11/23/2019 2:04:03 AM • Schlage Locks &... • Answered on Nov 23, 2019
I need to know if a Schlage be365 deadbolt 5 pin cylinder can be replaced with a 6 pin cylinder
I don't know if the deadbolt is the same as the BE-series lever-handle lock that I worked on, so this answer is about the lever-handle one:I just had that same problem last week! The short answer is, "No, you can't replace the cylinder," but if you are willing to do some surgery on the lock and take it apart (take a picture just before you remove each piece!), you can put a tiny opening on the cam on the back of the cylinder so a 6-pin key can go all the way into the cylinder and then go through the back. The cam comes off in a unique way: depress the tiny brass dot in it and then turn it about 1/4 turn (maybe a little more or less, I don't remember exactly) and it will come off. You can then rekey the cylinder to your key and, as I said, make that little hole in the cam. To make the hole, I used a Dremel rotary tool with a 1/16" diameter bit. To figure out exactly where to make the hole, I put some lipstick on the end of my key and pushed it all the way into the keyway before I took the cam off. (You could achieve the same thing by sharpening a straight piece of piano wire or spring steel wire, pushing it through to the back of the keyway and wiggling it a lot to make scratch marks.) Keep your hole as small as possible so you don't weaken the cam. Assemble everything back together and you can now use your 6-pin key.I'm being a little flippant here. The mechanism inside that lock is pretty complicated. I'm a locksmith with over 40 years experience, and while it took me only a few minutes to make that hole and rekey the cylinder, it took me about an hour to figure out how all the pieces that connected to the motor fit back into the case so they would allow the outside handle to engage the lock when the motor activated, how the wires needed to be put back in around the edges and not bind against anything, and finally to get the cover back on. Good luck!
10/12/2019 5:33:25 AM • Schlage Locks &... • Answered on Oct 12, 2019
I installed a new schlage dbl cyl deadbolt it works until I lock unlock the exterior side of the door then the interior side key turns to the point where it has to push the bolt to lock and it stops.
Since it is a new install and hasn't functioned properly ever, you probably have the bolt on backwards. Recheck all the parts against the assembly instructions
9/22/2019 2:51:02 AM • Schlage Locks &... • Answered on Sep 22, 2019
Schlage Electronic Lock FE595 Plymouth or Camelot series Logo
12 questions posted
Top Schlage Locks & Locksmithing Experts
john h
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Schlage Locks & Locksmithing
Most Popular Question
exploded view parts fe595 schlage
  • Locks & Locksmithing
