20 Most Recent Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Questions & Answers
2answers
Hammer action power there but weak
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
9/11/2018 10:53:11 AM • Bosch SDS-plus... • Answered on Sep 11, 2018
How to add oil to Bosch 11241Evs hammer drill
How much do you put in?
6/27/2018 6:35:58 PM • Bosch SDS-plus... • Answered on Jun 27, 2018
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
7/23/2016 2:01:50 PM • Bosch SDS-plus... • Answered on Jul 23, 2016
I have a bosh rotary hammer drill bulldog extreme hammers and drills half ways and then stops spinnig but continues to hammer. Help
  • If look at brushholder unmount it and make clean look if the brushes are go good to each other most causes on this BOSCH tools is that the brushes 70% are hanging on dirth in the brush holder (brushplate) 16 first problem second true problem are the 2 suppression coils (adapter module 817 ) on the electric field. and also parts pos 19 left right switch contacts for the brushes can sometimes on ofthem be broken.
http://www.powertools-aftersalesservice.com/public/bosch-pt/service?p_auth=3aqey22L&p_p_auth=svtCUe1o&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL2VuX1VTLy0vVVNEL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmNkZTdkNTFiZjM0NGE0YTU1ZjYzYTYyOGY0MkRvVWFTdFRIO3NpZD1QYnVpWlFuNGVZcGtyVjZMemRLLW5nWnpLM0FSaDhEanA3b2h6b3RZdmhBZ3hZcFR2eHM9
6/29/2016 4:09:42 PM • Bosch SDS-plus... • Answered on Jun 29, 2016
Where can i get rockworth concrete breaker brushes
model numbers are 3 different 0 611 255 539 0 611 255 739 3 611 B55 539 But brushes 1 617 000 525 are for all models the same bosch number. Online to buy ( 1 suggestion ) BOSCH CARBON BRUSHES GBS AND GSB PART 1 617 000 525 GBH 2 22E GBH 2 26DFR...
5/31/2016 3:24:57 AM • Bosch SDS-plus... • Answered on May 31, 2016
Bosch GBH 7 DE does anyone know what oil type/amount in gearbox
PG150 fully synthetic
2/23/2014 10:33:19 PM • Bosch SDS-plus... • Answered on Feb 23, 2014
2answers
Looking for an owners manual for a 5/8 bosch
If you go to Boschtools.com you will find the manual you are looking for. They are all on the web site.
12/8/2011 11:51:45 PM • Bosch SDS-plus... • Answered on Dec 08, 2011
Chisel bit will not lock
Are you sure you are locking it in right? The STS locking mechanism on most of these tools is sometimes hard to do, you have to sometimes really push hard while turning it until you hear an audible "click" to know it is seated.
4/6/2011 10:39:46 PM • Bosch SDS-plus... • Answered on Apr 06, 2011
Runs but doesnt engage rotary or hamer. the
there is a selector knob on the side that controls the tool functions for drill only/hammer with drill/ and hammer only. make sure it is in the proper setting. If it still doesn't rotate then you have a gear or a broken selector. If no hammer then you have worn o rings or a stuck ram. try the selector first and if still no change please be more specific if no hammer at all, or no rotation even when selector moved.
3/3/2011 5:56:50 PM • Bosch SDS-plus... • Answered on Mar 03, 2011
How do you remove selector knob on bosch 11255vsr
Rotate the selector to the 4 to 5 oclock position, or the 7-8 oclock postion, push the red button in all the way with a screw driver and pull the knob out. Certain model hammers you have to rotate to a slightly different position to remove the selector, you will have to try one, if it doesn't work try the other.
1/7/2011 9:35:27 PM • Bosch SDS-plus... • Answered on Jan 07, 2011
I dropped it and the pcb appears cracked. I cannot
I order all my bosch parts from www.toolpartsdirect.com. Reasonable prices, and fast delivery if the parts are in stock. Usually about two weeks of the parts needs to be ordered from Bosch. Good holidays
12/4/2010 6:50:46 PM • Bosch SDS-plus... • Answered on Dec 04, 2010
How to change chuck on bosch 11255VSR
11/2/2010 4:01:33 AM • Bosch SDS-plus... • Answered on Nov 02, 2010
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
43 questions posted
Top Bosch Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
jabbar huusain
jabbar huusain
Level 1 Expert
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
View Most Popular
Bosch Hammering
  • Bosch Hammering
Most Popular Question
runs but doesnt engage rotary or hamer
  • Hammering
