Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
I think the concept behind the Radiant Floor
Heating System is that Installed tubes or heating element, which contains water
beneath the floor, which warm our floor. For more information about Radiant
Floor system you can check this site.http://www.ps2i.biz/
Unfortunately this sounds like more than a blockage. If this was a blockage water would not drain, maybe fill in sink or dishwasher etc. If water is coming from walls probably means it is leaking from drain pipe in the wall. Which would mean opening wall to find leak. If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
If you are referring to limiting the temperature of the hot water to prevent scalding, then a tempering or mixing valve can be plumbed in between the cold and hot water lines. This type of valve adds cold water to the hot water and it is adjustable.
(1.5ft)^2 * Pi * 30 ft * 62.4 lbs/cu-ft = 13232.4 pounds plus the weight of the pipe which will vary depending on the material of the pipe.
You can find the weight of the pipe if you know the brand and material as most manufacturers will list the weight per foot in their catalog.
30 feet has about 11.94 cubic feet of whatever material the pipe is made of.
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
