20 Most Recent Toro 15" Electric Trimmer&Edger Questions & Answers
Where can I get 2 carbon brushes that need replacing on my electric motor?
Usually from the manufacturers web site. Try googling motor parts for your brand of trimmer.
6/23/2015 4:43:34 AM • Toro 15"... • Answered on Jun 23, 2015
Lawn trimer repair shops surrey/delta ..c.
Carb switch coil gas,gas lined primer bulb spark plug. Start with carb cleaner in the intake. If it starts move to carb.
3/12/2013 6:14:02 PM • Toro 15"... • Answered on Mar 12, 2013
0answers
How to open to open safety cap to replace string
Check here it should help
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
6/20/2011 4:00:01 PM • Toro 15"... • Answered on Jun 20, 2011
Weedeater line keeps breaking
I sounds like the line is old and has become brittle.
5/27/2010 2:37:15 PM • Toro 15"... • Answered on May 27, 2010
I cant figure out how to get more string through
get it spinning as fast as the motor will take it and tap the head on the ground at the same time.the centrifical force will feed out more line
5/20/2010 10:22:57 PM • Toro 15"... • Answered on May 20, 2010
The toro does not have tabs to press when
no images on screen
4/7/2010 10:49:09 PM • Toro 15"... • Answered on Apr 07, 2010
Cannot Open Spool Compartment
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
6/24/2009 9:50:30 AM • Toro 15"... • Answered on Jun 24, 2009
Cannot Remove Spool Compartment
Unplug first . Push down on spool easy and turn to were the groves do not line up and pull up . the spring may be rusted . Or a build up of grass is there to. It just sounds like you need to used a little bit muscle . Best of luck Ed.
6/18/2009 1:41:05 PM • Toro 15"... • Answered on Jun 18, 2009
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity. When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb. https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning ..
1/20/2024 9:51:29 AM • Toro Garden • Answered on Jan 20, 2024
We have a Toro Powervac that will not start. Vac has a new carburetor, new engine coil, new fuel lines, new spark plug and still will not start. Any suggestions?
did you make sure it has spark. i have learned over the years because an electronic is new doesn't mean its good? If it has spark remove the plug and put a bit of gas in the hole and re install plug see if it will fire on that gas. if it does its the carb something is probably blocking fuel. check the compression if its low compression it will not run. if u dont have a compression checker just remove the plug stick your finger tight over the plug hole and pull it over it should blow your finger off the hole.
9/17/2023 6:54:34 AM • Toro Garden • Answered on Sep 17, 2023
Hi, I would like to know what is the typical compression value of a Kohler 16HP singel cylinder engine?
Yes, decompression lowers cylinder pressure during low rpm while cranking. If you're concerned with compression, you need to do a leakdown test. Inexpensive (~$30) units are available through numerous eVendors. The leakdown test provides a metered volume of air that is translated and displayed on a pressure gauge simply labeled high (excessive leakage), moderate, or low (nominal leakage).
It's an L-head engine and once they get a few hundred hours run time, the valves wear into the hard seat, lash goes to zero, and they become hard to start. You can check valve lash by removing the crankcase breather (two screws). If lash is near zero, time for a valve job. Plenty of how to videos on the web. If it's easy start, just low power then less likely a valve lash issue.
There are many things that cause low power. Bad fuel, water in fuel (fuel bowl), fouled carburetor, poor spark, fouled plug, improper plug gap, wrong plug, weak ignition module.
9/12/2023 10:24:23 AM • Toro Garden • Answered on Sep 12, 2023
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
8/21/2023 3:49:43 PM • Toro Garden • Answered on Aug 21, 2023
Toro 15" Electric Trimmer&Edger Logo
15 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
get 2 carbon brushes need replacing
  • Garden
