20 Most Recent
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Questions & Answers
Poulan p1500 string trimmer string problems
Could be the cutting line, if it is getting hot and becoming soft before it feeds out, it can stick. Try not winding the cutting line as tightly, this will give some space between the line and allow it some space to cool. If this doesn't help, the line is the problem.
Poulan p1500 carburetor kit
If you need to get areplacement part, check the following site
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
What type sae 30 oil do I put in my bolens weedwackewr
if its two cycle then you have to use two cycle oil. You can buy the small container which you use in a 1 gallon gas can or you can buy a larger can and mix your gas yourself. The larger can works out cheaper and I have the small can which I keep refilling from the bigger can. If you buy your gas by the liter you put one small can in 4.5 liters of gas which is a gallon.
Fuel lines have deteriorated and need to replace
I just took mine to a local Poulon Repair shop about 16 miles away and they replaced the lines and the grommet and only charged $6. You can find someone in your area through the Poulon website:http://www.poulan.com/service-locator/
Replacing fuel tank on craftsman edger and other
ok If you have a Walbro WT series carb "without" a built on primer bulb
here it is. First off if the fuel lines disintegrated you MUST
disassemble it and clean it out. The MOST infintesimle speck of gas
line trapped, can allow good prime and bad operation. OK? Don't be lazy
on this. Just be delicate removing the flaps gasket and diaphram. ZAMA
GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a
cleaner, compressed air or blow good thru it. OK Now...Primer bulb,
Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas
tank (Connect filter screen to this in tank) to the short Straight
brass carb connector. Primer bulb suction goes to the bent carb brass
connector. If small line brings fuel "in" this other line sucks it back
"Thru the primer bulb" and the blow side of the primer bulb sends it
back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru
short brass connect on carb. Other carb connect goes to bulb suction
"IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back
to fuel tank". Trust me I know how frustrating a simple diagram is to
find online fo this set up. And if you have a carb problem on top of
the hook up uncertainty you got frustration. Not only was online help
hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ
could not tell me how!!! and thats no lie! Walbro has a "generic" carb
diagram but no "hook up info" specifically. Poulan don't list it
either. And these things routinly fall to pcs. all 3 of mine crumpled
together on yr. 3 of use.
