20 Most Recent
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Questions & Answers
Head Bolts torque
On the trimmers when torqing head bolts down,I dont bother looking for torque specs (theres some people that will shoot me for saying this). I just snug them up and then give each one a one quarter turn tighten up. Its always worked for me.
New poulan 2500 wont run well
Sounds like the fuel filter is particularly plugged. Maybe you had a little trash in your gas, or a bit of it was in the tank from manufacturing. Hopefully changing or blowing out the filter will help. That's the first thing I'd check.
What make of carburettor is on the dynamac strimer
I have yet to find parts for these, not worth the effort, I would replace the unit and sell for parts if it was under $150, or make the gaskets yourself, take apart and clean. Mostly I see failures beyond economical repair.
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
ENGINE STARS AND THEN DIES
Try changing the fuel filter and if that dont do it there is a small screen inside the carb that usually plugs up carefully disassemble it and clean it out with a good brand of carb cleaner
How do you adjust a walbro carbeurator
if it is a fairly late model you will need a carburator adjusting tool.you can get them on ebay then set each screw at about two turns and fine tune from there
Will not prime
Gonna have to rebuild the carb and replace the fuel lines. Go to ereplacement parts.com and get a diagram.
I rebuilt the carb as
I don't know who you are answering, but I can help you. You have to make sure you have spark at the plug first. Then we can go from there.
How did it act the last time it ran? Has it been sitting for a long time? Do you have fresh fuel? When you respond to me, put your answer in the comment box on this page.
Jim
