20 Most Recent
LG LRSC26980 Refrigerator Questions & Answers
Water running down beside ice maker
is the water over pouring into the ice cube trays? Some fridges have a adjustment option where you can choose how much water the fridge puts into the tray - modify this setting if you have it, or contact lg for a repair.
Ice tray sometimes stuck when dumping off ice
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
LG Model LFC23760
What type of filter should be installed on a LG model LFC23760 refrigerator?
How do you rmove the televison from the right-hand
You should move all funiture to the wall.You should move all subjects to walls. You should put more fragile things on that place where you will not bear the TV. If at you have the big TV that move it in parts or employ workers
