20 Most Recent Pride New Mobility Victory XL 4 Wheel Scooter Questions & Answers
Increase speed on pride victory scooter
Buy kamagra gold 100 Online is used for Enlarged prostate gland in male, Increased blood pressure in lungs and other conditions. Know about the uses, side effects, price, composition, substitutes, How it works, Lowest Price Online. Kamagra Gold 100mg Online buy with lowest Price Ever Online Pharmacy. Kamagra Gold 100mg Reviews.
2/27/2019 11:07:02 AM • Pride New... • Answered on Feb 27, 2019
Pride hurricane, pre 2004, when throttle is
Things to check : Condition of the brake actuator and the condition of the brake shoes. If there are no flashing lights indicating a problem with the controller, then I would think it's all mechanical.
9/3/2017 9:07:45 PM • Pride New... • Answered on Sep 03, 2017
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
9/3/2017 8:20:15 PM • Pride New... • Answered on Sep 03, 2017
2answers
I have a JET Mobility Model 2904JT-24 Battery
Blue Positive Brown negative, Yellow with green stripe is additional ground. many people are trying to use the 2904JT charger for a 24 volt charger for other things. I am using mine on an e bike that has 4 12 volt batteries. I charge them 2 at a time and it works well. It only shows voltage when the batteries are partially charged. Some kind of safety feature to keep you from charging a shorted battery. No schematics available, I took my chances and verified the Blue wire is positive. lol Good luck with you project or re wire. : )
9/5/2016 5:39:20 AM • Pride New... • Answered on Sep 05, 2016
Smoke came out of pride victory stearing column
Sell it and run!
8/2/2016 7:56:43 PM • Pride New... • Answered on Aug 02, 2016
Need to get the battery out
Two batteries usually. Lift the seat off, you may need help to wiggle it off and it's heavy. The bodywork underneath is lightly velcroed on, just ease it gently upmand off. photograph the battery/ cable layout for reference when reassembling. DO NOT SHORT CIRCUIT THE BATTERIES! It's easily done with a misplaced screwdriver or spanner.
6/2/2016 11:33:27 PM • Pride New... • Answered on Jun 02, 2016
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
6/2/2016 10:22:16 PM • Pride New... • Answered on Jun 02, 2016
Squeaking axles
It's almost certainly a slightly binding brake, it often happens, especially if you have a sticky hand brake cable/ leaver. I've posted a full answer here as another Pride post.
6/2/2016 10:01:00 PM • Pride New... • Answered on Jun 02, 2016
Where can i go to get my scooter fixed
call 1-800-800-8586 I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
6/1/2016 10:13:52 PM • Pride New... • Answered on Jun 01, 2016
What amp fuse for pride xl
Depends on which fuse it is. They are all color coded and standard car fuses. Take the blown fuse to a car accessory shop and buy the same color (colour) or find on eBay. There are two hidden high amp fuses that Pride wont admit exist under the rubber mat and floor hatch.
5/2/2016 10:59:11 PM • Pride New... • Answered on May 02, 2016
Hi what fuse does the victory pride xl take plz
hi ,where is the fuse you referring to lcoated , the battery one or the one located on the tiller stem ? Regards Rob www.gewizrepairs.co.uk
7/13/2015 8:51:39 PM • Pride New... • Answered on Jul 13, 2015
What amp fuse on pride victory xl keeps blowing fuse
Hello Brian,good man for caring for your Mum.Refer to the User Guide that refers to your Mums scooter,that will give you the correct size fuse.If you do not have a User Guide,visit the manufacturer website and request 1 be sent,it will be a few pound probably.I hope this helps,if not.Repost another question
6/18/2015 2:01:22 AM • Pride New... • Answered on Jun 18, 2015
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem. How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
6/16/2015 7:21:52 AM • Pride New... • Answered on Jun 16, 2015
Scooter slow in reverse
The drives on most scooters are programmed to be slow in reverse for safety reasons.
5/2/2015 6:32:31 PM • Pride New... • Answered on May 02, 2015
Speed pot knob for go go elite travelier
Pride's website has parts.
2/24/2015 5:01:41 AM • Pride New... • Answered on Feb 24, 2015
Streamer Sport 888WA fully charged but will not run, light meter constantly flashes all lights
check motor wheel it may be jam
5/30/2014 8:07:48 PM • Pride New... • Answered on May 30, 2014
Hi what amp fuse plz
hi, what one ? the one on the tiller stem or battery ? Regards Rob ww.gewizrepairs.co.uk
5/26/2014 8:19:28 AM • Pride New... • Answered on May 26, 2014
How do I start my mobility scooter?
hi, goto the following link and look for victory,, all the models are covered here.. http://www.pridemobility.com/international/uk/ukownersmanuals.asp Please rate my assistance.... Regard Rob www.gewizrepairs.co.uk
5/24/2014 10:13:50 PM • Pride New... • Answered on May 24, 2014
2answers
Cuantos Wat de potencia tiene el motor del Victory X L 4
Los motores tienen una potencia de 24 voltios y una corriente maxima de 40 amperios durante 10 segundos. Tambien se han valorado en 750 Watts.
4/19/2014 5:33:36 PM • Pride New... • Answered on Apr 19, 2014
Pride New Mobility Victory XL 4 Wheel Scooter Logo
75 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
start mobility scooter
  • Health & Beauty
