20 Most Recent LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Questions & Answers
PE Problem
I don't know of PE as a error for the dishwasher, however stranger things have happened.
Lg has had problems with older units prior to mar 07. They have had wires breaking in the door. If you turn off the power and remove the panel. Look for broken wires and or wires stuck in the insulation. Check for continuity as sometimes it can be an internal break. Fix this and you should be good. Oh put some insulation between before closing it up .
Sgt 48
6/25/2019 5:44:50 AM • LG 24 in.... • Answered on Jun 25, 2019
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
5/4/2015 4:41:30 PM • LG 24 in.... • Answered on May 04, 2015
Lg dishwasher won't drain
Have the drain pump checked out, if faulty you will need to replace it as it cannot be repaired.
1/4/2015 5:46:20 AM • LG 24 in.... • Answered on Jan 04, 2015
0answers
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
4/12/2014 8:44:45 AM • LG 24 in.... • Answered on Apr 12, 2014
0answers
0answers
0answers
3answers
Lg - LDS5811ST Dishwasher OE Error Code
hi
8/17/2013 8:40:02 AM • LG 24 in.... • Answered on Aug 17, 2013
0answers
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
125 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
39 ve lost manual lg ld 14at2
  • Dishwashers
