20 Most Recent
LG 24 in. LDF7810 Built-in Dishwasher Questions & Answers
WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Actually I found out that for a LG dishwasher it is as likely to be the cable/cord attached to the spring and door. This a very odd setup in that this cable is made of nylon cord, and not any thicker than a round shoelace! It clearly should be metal cable, and it's not that hard to replace the nylon stuff with steel. Anyway, it is worth it to pull the unit out and open the side panel to see if in facts it's a broken cord or spring first before ordering any parts.
1/24/2015 2:58:01 AM •
LG 24 in....
Answered
on Jan 24, 2015
My LG LDF7810ST dishwasher stops running after 12
Hello, kj
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
10/27/2011 9:20:10 PM •
LG 24 in....
Answered
on Oct 27, 2011
Leaking water on the right hand side
Does it seem to be coming from the door it self or from underneath the unit?
If it's coming from the door, check the seal or maybe replace it. It's easy enough and cheap.
(disconnect power before proceeding to the next step)
If it's coming from underneath the unit, first start a cycle to drain it then stop it. Pull the unit out and flip it to its side(have a couple towels ready), then remove the bottom cover and check hoses connects or any signs of leakage.
2/23/2011 1:14:26 AM •
LG 24 in....
Answered
on Feb 23, 2011
I have a LG LDF7810 WW. The bottom rack does not
Could be a bad VIRO motor. It moves a valve to change water flow between bottom spray arm and top spay arm about every 2 minutes of the wash cycle. You have to pull the dishwasher and lay it on it's back or side to change it, but you only need a phillips screwdriver.
2/7/2011 5:20:59 AM •
LG 24 in....
Answered
on Feb 07, 2011
Hi. I have an LG LDF7810 dishwasher. I did a deep
Hello ghouse. That grease was placed there in the factory to stop a leak in the seal that they had detected. Go to the auto parts store and get a tub of white grease and replace what you removed. Joe
Thanks for choosing Fixya!
1/7/2011 10:11:54 AM •
LG 24 in....
Answered
on Jan 07, 2011
The door is bent
Im not sure if they can help, but try www.applianceart.com. I know they make stainless steel panels to replace your old ones but not sure if its the type you need.
6/7/2010 10:41:45 PM •
LG 24 in....
Answered
on Jun 07, 2010
