20 Most Recent Poulan "Poulan" Push Mower Questions & Answers
How to adjust carb on a poulan weedeater lawnmower
I'm not sure about your year or generation mower. Does your Weedeater have a plastic Carb? If so, is it a one or two piece. You can clean them with gasoline or a cleaner called Deep Creep (From Sea Foam). A sonic jewelry cleaner does a fantastic job loosening up debris. Fill with some Simple Green or purple Magic and dilute with water. Anything harsh like CARB or BRAKE cleaner will mess up the Carb. If it is worn out then buy a new one for $25.
9/27/2018 2:59:26 AM • Poulan "Poulan"... • Answered on Sep 27, 2018
Where is the air filter in a poulan pro 550
Above the carburetor. Should be a plastic box with 1 - 3 screws holding it in place.
1/17/2018 9:28:16 PM • Poulan "Poulan"... • Answered on Jan 17, 2018
What type of oil does a 625 series take
wtfsrrgr0iwaaaabjru5erkjggg== xyx1ubgu9czaycz9w1lxhvkqpra0ndq0ndq0ndruc6jpzrdncgxoaghoaghoaljya0trq0ndq0ndq0ldkma1pa0ndq0ndq0ndq8nsqbo0njq0ndq0ndq0lhf03f8p59doznnsbb4aaaaasuvork5cyii=
1/8/2018 9:58:07 PM • Poulan "Poulan"... • Answered on Jan 08, 2018
I am having issues removing my oil cap on my bolens 21" push mower. Any ideas?
try useing a screwdriver in the slot
1/4/2018 1:08:50 AM • Poulan "Poulan"... • Answered on Jan 04, 2018
Lawn mower won't start...has gas and oil.
3 most common possibilities: Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only about as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging. Another very common problem is shearing the aluminum alignment pin in the top of the crankshaft when the mower whacks a log, root or rock. The inertia splits the alignment pin in half and throws spark timing off. So it backfires or won't run. Also check your spark by grounding the fat end of the sparkplug with a jumper cable to the engine casing, leave it plugged to the wire and pull the cord to see if it is firing. Keep spark away from fuel. Ignition points in some small engines get crusty when sitting in humid conditions. So they have to be filed clean of oxidation for proper contact and sparkplug operation. Small engines like rich mixtures and starting fluid when they are cold.
7/3/2016 6:35:10 AM • Poulan "Poulan"... • Answered on Jul 03, 2016
How do you repair a Bolens push mower that's leaking gas out of the carborator?
You will need to rebuild the carb sounds like the float is sticking and allowing the gas to keep flowing. The needle vale is probably sticking. Check around the carb first to be sure it not coming from the line that feeds the carb before taking it off.
12/17/2015 1:06:08 AM • Poulan "Poulan"... • Answered on Dec 17, 2015
How do i change the spark plug on my lawn mower
Pull the wire off the spark plug and then take a 3/4 inch spark plug wrench and loosen the plug and remove it. Be sure to check the gap on the plug before putting it in, they sometimes get hit when being handle so never put one in without checking the gap first.
12/17/2015 1:00:11 AM • Poulan "Poulan"... • Answered on Dec 17, 2015
2answers
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
5/18/2015 9:11:22 PM • Poulan "Poulan"... • Answered on May 18, 2015
3answers
Mower won't stay running
Assuming it is a B+S engine, if it starts fine and runs rough and smokey as it gets warm and will not get enough speed, the problem is with the Diaphragm between the carb and fuel tank, it costs about £3 and is easy to fit if you have a 10mm and 13mm spanners and a cross heded screwdriver, ver annoying but relatively cheap and simple fix. Max.
4/27/2015 3:36:11 AM • Poulan "Poulan"... • Answered on Apr 27, 2015
0answers
Warranty
Be the first to answer 2/26/2015 3:29:54 AM • Poulan "Poulan"... • Posted on Feb 26, 2015Be the first to answer
2answers
158cc briggs stratton carburetor diagram
one and half turn out to start then turn out or in fine tune it
9/4/2014 6:02:52 PM • Poulan "Poulan"... • Answered on Sep 04, 2014
HOW CAN I BUY BOLT??
you can obtain them from any mower shop,
8/10/2014 3:13:44 AM • Poulan "Poulan"... • Answered on Aug 10, 2014
Where is oil plug on poulan pro 500 mower
It may not have one. Some newer models you can only suck the oil or tip the mower after removing gas on its' side.
8/8/2014 3:32:59 PM • Poulan "Poulan"... • Answered on Aug 08, 2014
Briggs stratton timing
There should be 2 marks on the crankshaft and one on the cam. align these up and slowly tap the crankcase cover on. Slowly move the cover and be sure to align where the camshaft goes into the crank cover. Start one bolt then do the rest. Do not over tighten.
7/1/2014 3:17:24 AM • Poulan "Poulan"... • Answered on Jul 01, 2014
2answers
Poulan pro 550series lawn mower rust from tank
You still have trash in the carburetor blocking or partially blocking. You are going to have to get some spray carb cleaner and be very thorogh about cleaning it, every hole, every passage, every thing. While you are at it if you have not recently changed the diaphram, go ahead and do that since you have it apart. The diapham is not expensive.
6/11/2014 3:57:38 AM • Poulan "Poulan"... • Answered on Jun 11, 2014
I have recently bought a poluan pro mower. It has
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
6/7/2014 12:03:43 PM • Poulan "Poulan"... • Answered on Jun 07, 2014
I have a POULAN lawn mower that has sit unused for
Ensure that you refill it with new fresh fuel not the fuel that was left inside it as fuel does has a limited life.
Regards
Marc
6/5/2014 2:37:40 AM • Poulan "Poulan"... • Answered on Jun 05, 2014
Poulan "Poulan" Push Mower Logo
203 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
change air filter poulan 500 series
  • Garden
