20 Most Recent
Great Plains Industries Gpi& Fuel Pump Questions & Answers
How to change a fuel pump on a mazda 98 b4000
Before throwing more and more parts at the problem, first thing to check is fuel pressure, if it's OK, then that isn't the problem. It could be------a plugged catalytic converter, a failing ignition coil, bad plugs, distributor cap, ignition rotor, cracked/defective dist. cap, ignition module. The list can go on and on. Start with the basics. When was the last time a major tune up was performed? Smog check? We can minimize costs by figuring out the real problem first. If you are adamant about the pump, it's in the gas tank and you will need to drop it out of the truck to change it. Good luck
Can I use a inline fuel pump
Of course, it's free country (unless you are in North Korea). Where would you like to use it? On an oil furnace, a weed wacker perhaps?
1999 ford expiodition
use a pressure gauge to check pressure at the rail. Change fuel filter. Replace fuel pump if needed.
2001 gmc sierra fuel pump wont turn on
-First check fuse and relay. If all are good then
test continuity at pump connector for open. If not continuity then the pump is bad. replace new one.
Good luck
Mai Lor
Why will my1994 bravada not start?
line got clogged again? Check to see if it, the engine, is getting fuel . Go backwards for engine and see if fuel is gettign to fuel fiter, etc.
