20 Most Recent
Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac Questions & Answers
How do i change the oil on my chipper vac
that could be wiring issue that the batter isn't able to take up the electricity supplied to it.. u know, the conductor between them..
if possible get a manual from reliable-store to fix it urself
5hp troybilt chipper vac has no spark!!
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. l
et me know if u need help
thanks
Need to find a Bolens
some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed.
you can go there and try
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Won't start
check the fuel line it could be pluged up. never leave gas in any thing when you put it up for the winter.
Chipper Features
look for in chipping units is the ease with which you can change the size of the discharge screens that control chip size. This allows you to make chips for various landscaping needs.
I have a troy built chipper/vac model #47297 cant find parts 4 bager
Hi there's this website something like reliable-store and it is very amazing for manual for repairing
servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
both very good
How to I change the oil on my Troy bilt 47279
hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
cheap and mine
Try it out mann
Clogged fuel filter
take the line of the carby and check the fuel flow first
indicates that the carby is not filling ( jammed needle and seat) or the main jet is blocked
