20 Most Recent
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Questions & Answers
I need to replace motor on MTD chipper/shredder.
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
Yard machine chipper/shredder won't start
my chipper had problem with wiring issue that the battery isn't able to take up the electricity supplied to it.. u know, the conductor between them..
if possible get a manual from reliable-store to fix it urself thats I did
Problem with Yard Machines 120312 0158 E1 5.5 Hp
there's are website that I know all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
Chipper will not stay running . Needs continuous priming. won't chip
you can get guides online for error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
I know these websites
Hard to pull starter rope
I take help from online websites that have this service like helping in repair some have instant help.. others are a bit slow which I don't prefer... rest is up to us.. U can also get free manuals
Balde wheel is engaged while
No. The blade is like a flywheel and is connected directly on the motor shaft. However, these usually have separate choke and throttle handles. I have found that they start easiest if the throttle is set pretty low and the choke is closed. Once it starts to fire, then slowly open the choke - allowing it to pick up a bit of speed before you open the choke all of the way. Then wait a few seconds before turning up the throttle. On the other hand, if you have debris in the machine making it hard to turn, you will have to clean some of it out before you start it.
Good luck,
Al K
I would like to know
Hi, you can download the operator PDF manual for your chipper at this LINK. Type your model number like this ( 247.795940 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer where you can eithewr save it or print it out or both...
Yardman Chipper/Shredder won't run
I had this same problem after letting the machine sit for a couple of years with gas in it. What finally solved it for me was taking the screw out of the bottom of the carburetor bowl and cleaning it. I mean clean it. Carburetor cleaner or some other solvent helps but you've got to get the gunk out of that screw. It probably has an obvious "feed" that runs across the bottom part of the screw shaft. The "feed" that runs from this up to the carb is the tricky part. I needed something very fine and finally settled on a combination of strands of wire from a lamp cord. Try two or three strands twisted together and work it up and down with some carburetor cleaner.
5 HP B&S RUNS AT IDLE BUT WHEN ADVANCED TO FUL...
It could be the linkage, but the most likely problem is the throttle has gummed up in the idle position. Put thin oil or spray carburetor cleaner on throttle and move it back and forth to work it loose. I've seen it many times after an engine sits for awhile.
Need owners manual for 2001 yard machine chipper
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (
[email protected])
Will not start. It is 3 years old and has not been
You need to go over this machine thoroughly, disassemble carb and give it a full cleaning. Remove gas tank and clean thoroughly. Replace plug, change oil, new air filter the works! It should be fine after a little TLC, Good Luck and have fun!
I want to change the oil on my Yard Machines snow
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
