20 Most Recent
Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller Questions & Answers
Gas coming out of breather tube for rocker arm cover
Did you clean the needle valve/seat ?
Sounds like the float is not closing off the gas flow.
Could also be the float has a hole in it that let gas into the air chamber of the float. Be worth checking.
Pull the float and put it into hot water. If air bubbles come out the float has a hole.
We are trying to remove the wheels and tines from
there should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
