20 Most Recent Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model Questions & Answers
White smoke and oil dripping
that could be wiring issue that the batter isn't able to take up the electricity supplied to it.. u know, the conductor between them.. if possible get a manual from reliable-store to fix it urself
1/22/2019 10:00:10 AM • Yard Machines... • Answered on Jan 22, 2019
Where to buy replacement bag
there's a website reliable-store all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge let me know if u need more help regarding other websites Im a routine buyer
1/21/2019 9:57:09 AM • Yard Machines... • Answered on Jan 21, 2019
6.0 B/S yard man 21 inch cut wont stay running
1/21/2019 9:55:37 AM • Yard Machines... • Answered on Jan 21, 2019
Cant get the recoil handle to pull out i have to
some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
1/19/2019 10:14:54 AM • Yard Machines... • Answered on Jan 19, 2019
2answers
Same Problem with the 4.5hp B.S. 21" Yardmachine Walkbehind Mower
This is what I would do... Remove the fuel tank and carb assy.. Two bolts, one behind the gas cap and one on the end of the tank. Pull it straight off the intake pipe then unhook it from the throttle link. Now, unscrew the carb from the tank. Clean the carb with a can of carb cleaner. Slip the screen off the pickup and make sure it's clean. Discard the pump diaphragm and gasket. Buy a new pump diaphragm kit, part #795083. Clean the top of the tank where the pickup with the screen fits into. Put it back together. Remember to put the rubber diaphragm against the tank and the gasket on top of it then the carb. Don't forget to attach the breather tube when you're putting it back on the engine. That should fix 'er up. Also, if the rubber ring and plastic retainer ring came off on the intake pipe when you pulled the carb and tank off, put them back in the end of the carb before sliding it back on the intake.
12/16/2012 2:59:01 AM • Yard Machines... • Answered on Dec 16, 2012
I have a Tecumseh 4.5 2 cycle engine on my snow
fuel filter thats were i would check fuel will turn gummy in the filter if it sets
2/1/2011 2:19:19 AM • Yard Machines... • Answered on Feb 01, 2011
After turning on it began
For safety remove the spark plug and disconnect it from the plug wire. Tilt the machine back and rotate the blade by hand and make sure it clears the mower deck all the way around. Check to see if blade is tight. Any movement of the blade on the shaft is unacceptable. Tighten blade, if it won't start with blade tightened it may have sheared the flywheel key.
10/14/2010 10:31:07 PM • Yard Machines... • Answered on Oct 14, 2010
Engin smokes uses 1 qt
Worn rings/valve stem seals
9/12/2010 12:13:32 AM • Yard Machines... • Answered on Sep 12, 2010
3answers
Lawnmower won't start
I am not having any luck with crossing the number you passed. I really need just the number off the engine air shroud just above the spark plug. Having said that. I understand you have a fixed speed automatic choke Briggs and Stratton engine without a primer bulb.
To gain access to the carb diaphram it is not that hard. The carb and gas tank are removable with just 2 bolts after the air-cleaner is removed. One bolt with spacer is near the gas filler opening and takes a 1/2 inch socket to remove. The other bolt is on the front bracket and is a 3/8 head. Once you have the bolts out, pull gently and carb will slide off of the intake tube.
Then tip the bottom of the carb toward you (STOP note the linkage position) and then remove the linkage.
Tank and carb off....
NOTE: The diaphram may stick to either the tank or the base of the carb so be careful when separating carb from the gas tank. Remove the 5 screws holding the carb to the tank and lift straight up making sure the diaphrm is not stuck.
The diaphram is under the carb and will have a spring on it if yours has an automatic choke. Note which side of the diaphram the spring is on. On the side of the carb there will be a rectangular plate with ONE 1/4" head on it. Remove the plate. This is where the choke attaches to the diaphram. Before removing the diaphram inspect it for holes in places where is not supposed to
have holes. If there are no holes visible on the bottom of the diaphram remove the diaphram by disonnecting the linkage inside the side plate. Again inspect the top of the diaphram for holes. If you find any tears or holes take the diaphram to your nearest lawnmower parts supply and get a replacement. They
usually cost around $6.00
If your carb has a single fuel adjustment screw turn it closed until it just starts to snug up counting exact number of turns from the original position.
Remove the fuel adjustment screw. If you loosen it until it is almost removed the whole assy will pull out with pliers while screw is still installed.
(O-ring type mating area) Clean the hole and reinstall the fuel adjustment jet.
Turn it closed until snug then adjust to original position.
NO HOLES in Diaphram or before installing NEW diaphram.
Check the fuel pick up tube for obstructions especially on the bottom screen.
You should be able to pass air though the tube orally. Noting the tube is free of obstructions install the diaphram by connecting the choke link on the side of the carb and install the side plate. Install the carb onto the gas tank and evenly tighten the mating screws. Then take the tank and carb assy to the engine and connect the carb linkage. Slide the carb onto the intake tube and make
sure the O-ring on the intake tube is inside the carb intake throat. Install the 2 mounting bolts for the tank and carb assy.
Test engine.
Install the air cleaner screw. Fill the gas tank all the way to the lip of the tank where the gas cap screws on. (This will ensure that the diaphram has gas in it) It should start within 2 or 3 pulls.
If it runs... your almost done.
AIR CLEANER
Take the air cleaner foam and wash it with gas until clean. Then oil the filter with oil gently squeezing it to make sure oil is evenly distributed.
Once oil is evenly distributed SQUEEZE out all excess oil by squeezing the foam as tightly as you can. Then install the foam and air cleaner.
Task complete.
Thanks for using FixYa
Kelly
5/5/2010 7:05:54 PM • Yard Machines... • Answered on May 05, 2010
I have a yard-man 6.75 hp,190cc self-propelled
This is how to clean the fuel passages in the carb for a honda type OHV engine.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
If the above does NOT apply to your engine then please respond with the engine type model number off of the air shroud just above the spark plug. ALL of the type model numbers will be needed. Also in some cases the serial number.
4/13/2010 11:38:00 PM • Yard Machines... • Answered on Apr 13, 2010
24a-020d700 won't start, new gas & replaced
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
1/7/2010 2:08:52 PM • Yard Machines... • Answered on Jan 07, 2010
Have a Lawn Machine with a 14.5 HP B&S motor.
sounds more likley to be a dirty jet in the carb,
the brigs and straton engine never did have a very good carb fitted wip off the flote bole and clean out carb and all the jets,,,
11/5/2009 11:53:03 PM • Yard Machines... • Answered on Nov 05, 2009
My riding mower blade engages before i engage it
It sounds like the blade brakes are worn out. If you look under neath the frame,where your feet rest, you sound see an arm with a brake pad on it.
It may be time to replace them.
Go to www.precisonope.com, put your information in under OEM parts. It will give you a diagram and parts list. You can find your part number for the blade brakes.
Good Day.
10/12/2009 6:36:13 PM • Yard Machines... • Answered on Oct 12, 2009
Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
9/16/2009 10:46:23 AM • Yard Machines... • Answered on Sep 16, 2009
Mower wont start
If the starter seems fine and all the wires are ok. Including the ground is securley grounded on the battery then it would have to be the voltage regulator only thing left that sends power to start it
4/29/2009 10:49:10 PM • Yard Machines... • Answered on Apr 29, 2009
Will not start
sounds like water in the carb bowl - loosen nut on bottom of carb to drain and retighten then try to restart
10/27/2008 6:11:01 PM • Yard Machines... • Answered on Oct 27, 2008
Chipper is jammed. need to know how to unjam
i have a chipper too, and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
1/23/2019 8:59:56 AM • Yard Machines... • Answered on Jan 23, 2019
How do i replace a pull cord on a craftsman chipper/shredder?
why don't u try online some websites deal in it real time.. along with solutions to problems how to repair fix service nd all its free so no big deal in trying let me know if u need some help
1/23/2019 8:57:46 AM • Yard Machines... • Answered on Jan 23, 2019
I have a craftsman chipper shredder model #
Some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try most shredder owners know about it it's free so no harm in trying
1/21/2019 9:53:41 AM • Yard Machines... • Answered on Jan 21, 2019
Have 4 ton yardworks splitter, no manual....
Some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try most shredder owners know aboutt it it's free so no harm in trying
1/21/2019 9:15:00 AM • Yard Machines... • Answered on Jan 21, 2019
Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model Logo
Popular Tags
23 questions posted
Top Yard Machines Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Heavy Machinery
Most Popular Question
after turning began
  • Heavy Machinery
