20 Most Recent Sharper Image Ionic Breeze 3.0 Air Purifier Questions & Answers
2answers
My Purifier just stopped working.
Hi.
Parts for the unit are not available anymore. In any case I suggest not repairing the unit. There had been health and safety issue related to this kind of purifier.
Here an article: Hi. Parts for this unit, including the filter are not on sale anymore, as all Ionic Breezemodels had
5/10/2023 4:25:25 PM • Sharper Image... • Answered on May 10, 2023
12answers
Ionic breeze 3.0 repair
My Ionic Breeze GP began losing power occasionally but I could shake it and get it to turn back on. It got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not to be recommended, but I consider the sacrificing the switch for the back cover to be introducing only limited risk, so I might take that route if I have to.
11/2/2020 4:10:59 PM • Sharper Image... • Answered on Nov 02, 2020
0answers
I have the Ionic Breeze Hybrid GP from Sharper
had the same problem, sparking in the lower section. i cleaned the grid blades on the filter with a scotch brite pad thoroughly in the area that was sparking and cleaned the corona wires inside the back of the unit gently by rubbing with light grade sandpaper. the unit runs like new. give it a try.
4/26/2015 4:23:19 AM • Sharper Image... • Answered on Apr 26, 2015
5answers
Broken internal wire
There are no replacement parts for these devices. the parent company that distributed these units are no longer servicing the units. Sharper filed for bankruptcy two years ago.
5/15/2014 3:14:11 AM • Sharper Image... • Answered on May 15, 2014
0answers
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
196 questions posted
Top Sharper Image Air Purifiers Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Sharper Image Air Purifiers
Most Popular Question
turn when button pushed
  • Air Purifiers
