20 Most Recent Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM Questions & Answers
See if you have spark to the plug, if not replace coil. You did everything else it should start, make sure start switch is to the on position. You replaced carb are the lines connected to the correct places and not kinked. Is your clunk clean. not much else to go wrong. Good Luck......
Troy-Bilt... | Answered on Oct 02, 2013
Check the fuel pump or fuel injector.
Troy-Bilt... | Answered on Sep 12, 2013
If there is no compression and it is a 2 cycle engine the motor is bad.
Troy-Bilt... | Answered on Dec 26, 2010
souds like it could be flooding out at full revs check the choke is fully closed
Troy-Bilt... | Answered on Jul 26, 2010
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see day light through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Troy-Bilt... | Answered on Dec 03, 2009
Hello:
Remove the Muffler and Look into the Exhaust Port.
If the Piston has Scratches or Gouges, then the Engine is Trashed and will have to be Replaced.
A New Unit is Usually Cheaper than Buying the Replacement Parts.
You can View a Breakdown of this Unit at the Following Site Addy.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
Troy-Bilt... | Answered on May 10, 2009
10-30 w, or SAE30 eg Briggs & Stratton 30.
Troy-Bilt... | Answered on Mar 22, 2009
If the either burned, then you have a fuel problem. Make sure the fuel filter (in the tank) and the lines are all clear. If so, then you my need to rebiud the carburator.
Troy-Bilt... | Answered on Jan 30, 2009
dont even mess with it. take it back and get another one or your money back...next time buy an ariens
Troy Garden | Answered 3 days ago
See engine operators manual. The fuel shutoff lever is below the throttle lever.
https://www.troybilt.com/webapp/wcs/stores/servlet/DisplayOwnersManualList?storeId=10001&catalogId=14102&langId=-1&logoCode=02&modelNumber=31AS62N2711
Troy Garden | Answered on Dec 13, 2019
If you want to try and do it yourself?
Remove all the old stale fuel
Remove, strip and clean the carburetor
Remove the spark plug and replace with a new one
Refill with fresh fuel
Start your engines :>)
Or get it serviced locally
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ACYBGNTsa0kJLNly6n65do2Cc7ZGcyIg-g%3A1574887670920&ei=9uDeXcHnN4LI_Qa6uagw&q=troy+bilt+snowblower+service+near+me&oq=troy+snowblower+service
Troy Garden | Answered on Nov 27, 2019
This is because one of the blade connecting rods in the gearbox is no longer connected to one of the blades, this will require opening the gearbox cover to assess what has come adrift.
Troy Garden | Answered on Oct 21, 2019
CONTACT A DEALER OF SAME
Troy Garden | Answered on Oct 13, 2019
On this model the brake must be ON and PTO OFF for engine to crank.
Turning ignition switch to start position connects battery to the ignition switch "S" pole, then goes through the brake switch then through the PTO switch to the starter solenoid.
Troy Garden | Answered on Oct 07, 2019
First check the being fuel needle in the carb. It might not be seating properly. It may have a groove worn in it. Depending it's age. Or it could be a dirty float bowl housing or a leaking float bowl.
Troy Garden | Answered on Oct 05, 2019
Remove the belt and check that each pulley spins freely, grease your spindles, sometimes only accessible from underneath the deck. Check that nothing is wrapped around the spindles under the blades. Your belt tensioner spring could be worn out, assuming you have the correct belt installed.
Troy Garden | Answered on Sep 25, 2019
4 stroke uses motor oil in the sump. 2 stroke uses oil and fuel mix. Read your user manual!
Troy Garden | Answered on Sep 11, 2019
Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM Logo
9 questions posted
Top Troy Garden Experts
Neil Hancock
Joseph Mueller
Joseph Mueller
dannydoesita
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
31 cc troy
  • Garden
