20 Most Recent
Swisher 60" 26 Hp Zero Turn Radius Riding Mower #Zt2660b Questions & Answers
Swisher model ztr2460ka return to neutral adjustment
You don't. The problem is usually in the pivot bolt for the steering handles. Pull the side covers of and replace the pivot bolt. I replaced with stainless steel bolt and went oversize with the hole so I could instal a bushing. This remedied the poor design and I have had no further problems. The hardware needed can be purchased at most any hardware store or TSC.
White Horse Zero Radius 54" deck. Transmission
check that the drive pulley to the hydraulic unit is still fixed to he shaft and has not got loose and just turning but not driving the pump shaft. Other than that you may have to check out the pump pressure of the drive unit.
I have a swisher z-max
Your idler pooly is the culprit. The idler pooly should have no kind of play at all. Rock it up and down if it moves replace it.
Belt drive
I think that machine has one belt that runs everything the deck. If it does you should have a tent ion poorly release it and the belt will slacken up so you can pull the belt off. If the tent ion poorly is not on the deck then it will be under the machine just look for the poorly that puts tent ion on the belt. Let me I know how it goes good luck.
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
The 83
drop the deck and check all of the moving parts. you have a part that is frozen up, maybe a single blade pulley wheel which is causing this.
