20 Most Recent Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Questions & Answers
Assuming this is a Craftsman, there is an adjustment for height, but mainly just for leveling purposes. There is a nut on each side in the center of the hanger and unless these are all the way to the bottom end, it's not going to raise the deck that high. I would look carefully at the deck hanger mechanism on each side. Something is obviously not right. Has it always been like this, or did you just get the mower? You can go to.. http://www.searspartsdirect.com/partsdirect/index.action Then enter the model number that's under the seat, hit search, then scroll down to Lift Assembly for a look at how it is set up. I have seen broken hanger rods as well as a broken weld on the lift handle where it's attached to the cross shaft. Hope this helps..
Craftsman 21 Hp... | Answered on Jun 06, 2019
very first thing to check is pressure switches most have 3 one on the brake one on the seat and one on the blade engage lever onor more of these may be bad ParysTreeRepairClinic may have a video on how to check these
Craftsman 21 Hp... | Answered on Mar 18, 2018
sounds like you need to go to parts direct.com inter your make model and what you need they will help you can talk to a expert
Craftsman 21 Hp... | Answered on Jan 10, 2018
Hi, Have you tried to turn the blades by hand ( WITH THE MOTOR OFF ) I suspect there may be some transit packing that you may have missed. The blades should turn freely with the motor off and the blade engaged. There is a blade brake which stops the blades turning when the drive is disengaged which might need adjusting .
Hope this helps.
Craftsman 21 Hp... | Answered on Dec 31, 2017
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Craftsman 21 Hp... | Answered on Jul 25, 2017
Take the spark plug out and see if it is wet with gas. Could be bad cable, bad plug, leak in carburetor gasket
Craftsman 21 Hp... | Answered on Jul 20, 2016
The way that this engine is turned off is to ground the wire to the ignition module. This is located under the flywheel shroud bolted next to the flywheel, as the flywheel spins this module makes electricity and stores it till the magnet on the flywheels trips it and it dumps its electricity out the spark plug wire. It is everything that has anything to do with spark. that little ground wire on it is what shuts it off. this ground wire is ran in series through many safety switches including seat, blades,transmission,brake and also the Key switch.If everything is right this will allow the little wire to be ungrounded and it will have spark.I feel to make this story complete ,when the key is on there is also electricity through the key switch from the battery feeding the fuel solenoid on the bottom of the carburetor which will also shut of the engine from the lack of fuel but has nothing to do with spark but one more pain in the safety nightmare.Short of throwing money at this mower you need to know if it is one of the safety or key switch or if it is the ignition module. Remove the flywheel shroud, unplug the little wire , it should be a flat spade , turn it over with the key and see if you have spark. If you do then it is the tractor safety's or key switch . Let us know at the end of your test. Briggs and Stratton Modules
Craftsman 21 Hp... | Answered on Mar 20, 2016
.004 to .006 on both intake and exhaust. Keep in mind it has a compression release on the cam shaft exhaust valve side so if it is to tight it will not allow the exhaust valve to shut and will burn out with time as well as power reduction. Too loose will make it hard to turn the engine over,sounds like a low battery. I have had two of the Intec engines that the stud that the rocker arm pivots on pulled out of the engine head a little at a time and drove me crazy until it finally pulled all the way out. I would adjust on Mon, Wen, Fri .
Craftsman 21 Hp... | Answered on Mar 13, 2016
Lean mixture or the fuel shut off solenoid has lost power.
Craftsman 21 Hp... | Answered on Mar 08, 2016
clutch pedal is only to tighten a belt look under the mower and U might see what came loose
Craftsman 21 Hp... | Answered on Mar 02, 2016
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Craftsman 21 Hp... | Answered on Sep 21, 2015
Check the oil is it low...some engines have a low oil shut down...and will not start or run when too low Good luck
take out the spark plug then plug it up and hold it agains the frame or somthing metal and crank it over if it sparks your getting fire
Craftsman 21 Hp... | Answered on Jul 10, 2015
sounds like you need valves adjusted. either google your engine model number and "valve adjustment", or let me know what the # is and i can try to find a link.
Craftsman 21 Hp... | Answered on May 08, 2015
Your spark plugs are on the end of wires, typically near the top of the engine. You likely have more than one.
May be the drive belt is slipping. When did you last change or check it?
Is the belt shiny and showing small cracks ?
Craftsman 21 Hp... | Answered on Mar 14, 2015
they should not be able to hit each other. remove them and make sure they are not bent.
Craftsman 21 Hp... | Answered on Sep 19, 2014
http://www.manualslib.com/manual/497849/Craftsman-917-276181.html?page=22#manual
Craftsman 21 Hp... | Answered on Sep 18, 2014
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
294 questions posted
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
deck not high enough
  • Garden
