20 Most Recent Pride Mobility Victory 3 Wheel Electric Scooter Questions & Answers
2answers
My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
8/25/2021 10:11:21 AM • Pride Mobility... • Answered on Aug 25, 2021
Owners Manual
http://www.seniorsdirectservices.net/sitebuildercontent/sitebuilderfiles/2000manual.pdf
2/18/2021 6:12:59 PM • Pride Mobility... • Answered on Feb 18, 2021
I have a Pride Victory 10 4 wheel, how do I increase the speed? Other than the control knob turtle to rabbit. There must be a setting some where, the scooter is very slow. Thanks
Buy kamagra gold 100 Online is used for Enlarged prostate gland in male, Increased blood pressure in lungs and other conditions. Know about the uses, side effects, price, composition, substitutes, How it works, Lowest Price Online. Kamagra Gold 100mg Online buy with lowest Price Ever Online Pharmacy. Kamagra Gold 100mg Reviews.
2/27/2019 11:08:44 AM • Pride Mobility... • Answered on Feb 27, 2019
How dose my scooter stop
right, what scooter is it, You can try putting it in reverse slowly and that will bring your scooter to halt then reverse so take care, what brand and model of scooter ? Regards GeWiz
10/2/2017 9:01:01 PM • Pride Mobility... • Answered on Oct 02, 2017
Pride Victory scooter repair manual
Piggies might fly = Pride don't want you to go anywhere near one.
8/2/2016 7:58:31 PM • Pride Mobility... • Answered on Aug 02, 2016
Want to see why my batteries wont charge. Product is new !
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
7/25/2015 1:10:40 AM • Pride Mobility... • Answered on Jul 25, 2015
I have a victory pride and the tiller seems loose. Is there a bearing that I can replace.
there may be a loose bolt, I would see if someione you know has any mechanical ability and may be able to fix it easily or tell you what it needs.
7/14/2015 4:06:54 AM • Pride Mobility... • Answered on Jul 14, 2015
Pride V10 ****** wont hold a charge. It runs out of power afetr 10 minutes,
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger... Regards Rob www.gewizrepairs.co.uk
7/10/2015 7:48:38 PM • Pride Mobility... • Answered on Jul 10, 2015
Motor draws too much current
The motor has 2 brushes under a circular cap on the sides of the motor. When they wear down, they can use more current. Look there first. Then move on to the brake unit that is connected to the motor. If it doesn't release completely then excessive current will be drawn to move the scooter.
2/24/2015 6:14:54 AM • Pride Mobility... • Answered on Feb 24, 2015
Having problems starting my scooter
I have the same prob ! Try thses, I have cleaned the carb, ive checked for a spark (yes), cleaned fuel tank and checked to see if it is getting fuel and it is, also reset the air/fuel screw 1 and a half turns to factory reset NOTHING :( and took spark plug out and put my thumb over the hole pulled the pull start and it feels like it has pressure. Oh and yes I did put 2 stroke oil in the fuel !
2/19/2015 9:35:09 PM • Pride Mobility... • Answered on Feb 19, 2015
Pride Mobility Scooter just put in new batteries went to the shops and on the way back just stopped had to push it home not good shop is only 1Km away now it seems ok but don't want to risk it. Red li
Needs a full overnight charge of at least 12 hours and left on charge even when the lights tell you it's is charged up.then get into the habit of running it right down to improve the storage stamina of battery.good idea to take charger out with you so if you get a chance to top it up somewhere whilst away from home.remember in cold weather these things can't travel as far.
12/9/2014 9:00:40 PM • Pride Mobility... • Answered on Dec 09, 2014
Does anyone know where I can find schematics for pride victory?
You need to adjust the tow in. There is adjustment underneath.
11/25/2014 10:16:11 PM • Pride Mobility... • Answered on Nov 25, 2014
How can I correct the steering on my pride victory 3 wheeler?
lift dust boot on the bottom section of the yoke below the fiberglas covers and the yoke tilt adjustment, the adjustments are located at this nifty hiding place
8/27/2014 8:27:29 PM • Pride Mobility... • Answered on Aug 27, 2014
Why does the brake clutch chatter and the scooter will not move
Your motor and/or brake is more than likely bad.
8/26/2014 5:44:22 PM • Pride Mobility... • Answered on Aug 26, 2014
My victory 3 loses power. After about 13 minutets of riding, the motor gets hot and trips the circuit. Batterey meter when the throttle is pushed, goes to yellow before it trips the breaker. After
either a battery or cable problem long stretch would be breaker and lastly motor if cables get hot try replace them first with larger wire sounds like a resistance problem assumeing your batteries are good and motor brushes good
7/2/2014 6:51:34 PM • Pride Mobility... • Answered on Jul 02, 2014
I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
4/29/2014 12:26:51 PM • Pride Mobility... • Answered on Apr 29, 2014
5 slow beeps
check your charger - or your battery or both - my thought is the charging unit failed and is not charging to full battery
4/5/2014 4:29:04 PM • Pride Mobility... • Answered on Apr 05, 2014
If it is the brake mech or the freewheel then what can I do ?
Hello,if you look at it yourself & then take it to a shop repair place.A lot will not touch it if they know you have attempted a repair yourself.Please feel free to ask another question if you like.Have a nice day.Colin
5/12/2013 9:37:05 AM • Pride Mobility... • Answered on May 12, 2013
Pride Mobility Victory 3 Wheel Electric Scooter Logo
77 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
pride victory 10 4 wheel increase
  • Health & Beauty
