20 Most Recent
Pride Legend XL Heavy-Duty 4 Wheel Scooter Questions & Answers
Seat
Oh yes it will! They can be very stiff and heavy, get help and mind your back! Release the seat swivel leaver and wiggle the seat left and right as you rupture yourself lifting..... You probably need help I do these days.
My Legend XL is two years old (Model SC3450) and a
The problem of your legend XL can view from two different ways and also be view at same time from point.
1). From the wire connections and
2). From the ulterlator (i.e motor battery changer).
What you are to do to fix up this problem is to carefuly trace the wire of the power connector if it providing power on to the battery ,if dose not then it means that there is a power faile from the power which has been the couse of the power faile of the battery.
Then the wireing programm will need to be rerun so a to solve the battery problem.
Thank you and thank for using fixya.
Scooter is twoyears old and will operate for only
Don about the only thing left to check is the brushes in the motor and the brake. You can remove the brush caps and check to make sure that the brushes are not worn badly. You can also chek the rear of the scooter where the brake and the motor are attached and after a period of driving this area can be warm but not very warm or hot to touch. If it is hot or very warm then the brake is dragging and causing an excessive draw on the batteries. You can have the brake replace or take it off and clean the brake pad. Careful don't pull or break the wires going to the brake. Hope this helps let me know if it did Good Luck
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
The latch won't stay latched on pride jet 3 ultra
If the latch on your Pride Jet 3 Ultra power wheelchair won't stay latched, there are a few potential causes and solutions you can try:
- Check for obstructions: Inspect the latch mechanism and the surrounding area for any obstructions or debris that may be preventing it from latching properly. Remove any obstacles and ensure that the latch can move freely.
- Adjust the latch position: Sometimes, the latch may need to be adjusted to ensure a proper fit. Check if there are any adjustable components on the latch mechanism and try repositioning them to achieve a secure latch.
- Tighten or replace the latch: If the latch is loose or worn out, it may not hold securely. Check if there are any screws or fasteners that can be tightened to secure the latch. If tightening doesn't solve the issue, you may need to replace the latch with a new one.
- Seek professional assistance: If the latch continues to have issues or you are unsure about making adjustments or replacements yourself, it's best to contact Pride Mobility or a certified technician for further assistance. They will have the expertise to diagnose the problem and provide the appropriate solution.
