20 Most Recent Pride Victory 4 Wheel Mid-Size Electric Scooter Questions & Answers
I'm trying to fix a pride victory twin it flashes 5 times
NEVER EVER Bypass stuff. They are there for a reason and it is normally safety! ? ? ? ? ? (5) The manual freewheel lever is in the (forward) freewheel position. Remove the key from the key switch, then push the manual freewheel lever to the drive (rearward) position and restart your scooter Page 37 of your manual! https://www.pridemobility.com/pdf/owners_manuals/intl_scooter/canada/english_pdf/ca_victory_twin_om.pdf ..
8/6/2021 3:07:32 AM • Pride Victory 4... • Answered on Aug 06, 2021
Were is reset switch
It's usually a white button down at floor level between your heels
8/2/2016 7:15:38 PM • Pride Victory 4... • Answered on Aug 02, 2016
What is the lever for
There are several the right hand tiller leaver is for adjusting the tiller pitch the left hand tiller leaver is the hand brake - keep that lubricated and squirt a bit of wd40 down the inside of the brake cable if you can. The leaver on the right of the seat post is the motor brake freewheel leaver, the seat leavers are for swivel, back pitch.
6/3/2016 12:07:22 AM • Pride Victory 4... • Answered on Jun 03, 2016
Hooked up charger sparked melted the plug
Change the XLR PLUG ( three pin male or chassais female are easily found on the internet. Always plug the carger to the mains supply last and remove the mains end plug first when unplugging. check for shorted wiring inside the XLR plug
6/2/2016 11:59:30 PM • Pride Victory 4... • Answered on Jun 02, 2016
NEED A ELECTROMAGNETIC BRAKE WARNER MADE 24 V 4 ONM BRK 803 001
hi Mariano, please remember it does not have to be the exact brake as long as the watt and fittings are the same it will work.. Regards...
3/3/2016 11:06:17 PM • Pride Victory 4... • Answered on Mar 03, 2016
I need a wiring diagram for m Pride victory mobility scooter. Where can I get one?
hi sadly you won't however i can help , what's the problem ? Regards Rob www.gewizrepairs.co.uk
7/10/2015 7:50:31 PM • Pride Victory 4... • Answered on Jul 10, 2015
What does the 7 beep code mean on my Victory Pride 10 mean when I turn the key on ?
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me Regards Rob www.gewizrepairs.co.uk
7/10/2015 7:47:38 PM • Pride Victory 4... • Answered on Jul 10, 2015
3answers
I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
12/30/2014 5:54:11 PM • Pride Victory 4... • Answered on Dec 30, 2014
Where do you find the model or year on a Victory scooter
hi, they cover a span of five years, what do you need to know ? or require , the later ones did not have a inbuilt charger... Regards gewizrepairs.co.uk
12/22/2014 7:52:36 PM • Pride Victory 4... • Answered on Dec 22, 2014
I need a wiring diagram for my Pride victory 3 wheel scooter. Where can I get one mine is all messed up?
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
7/9/2014 10:38:50 PM • Pride Victory 4... • Answered on Jul 09, 2014
What year is my pride victory scooter
hi , i suggest you call Pride and give them the serial number ... What's your location and i get you a phone number... Regards Rob. www.facebook.com/gewizrepairs
5/24/2014 10:18:26 PM • Pride Victory 4... • Answered on May 24, 2014
2answers
Year of manufacture
If it is an SC1700, the year is 2008. I will verify for sure if I can find located on the scooter somewhere.
4/7/2014 1:05:48 PM • Pride Victory 4... • Answered on Apr 07, 2014
3answers
What year is my scooter
Neil is right, the serial number is on the seat support. From that the year can be determined. It's mostly moot, as Pride only has a 1 year warranty, and after that, it Parts and Labor. Why are you asking?
4/2/2014 9:23:27 PM • Pride Victory 4... • Answered on Apr 02, 2014
I HAVE BOUGHT A SECOND HAND ROMA SCOOTER. MODEL:
Hi. MostPride scooters have the serial number on the front of the seat support colomn. You will have to remove the seat and the cover over the batteries to see it. Good luck. Neil.
4/1/2014 11:18:08 PM • Pride Victory 4... • Answered on Apr 01, 2014
Scooter only moves a short distance, then stops?
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...Regardswww.gewizrepairs.co.uk?fixya
11/17/2013 4:52:03 PM • Pride Victory 4... • Answered on Nov 17, 2013
Scooter won,t move just clicks if I take the seat
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest.... Regardswww.gewizrepairs.co.uk
11/16/2013 10:51:12 PM • Pride Victory 4... • Answered on Nov 16, 2013
Service manual
should be a download manual on web
10/20/2013 8:02:33 PM • Pride Victory 4... • Answered on Oct 20, 2013
Where can I get a manual with pictures showing
The batteries are under the seat, which you need to take off and the cover as well. The key only turns the scooter on/off.Dan
10/16/2013 4:24:36 PM • Pride Victory 4... • Answered on Oct 16, 2013
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
49 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
find model or year victory scooter
  • Health & Beauty
