20 Most Recent Pride Rally 3 Wheel Scooter Questions & Answers
2answers
Old Pride Rally won't charge or run
The batteries may be too old to take a charge. They are gell cell types and can be had at any battery shop. You can get them on line too, but shipping will be high.
8/26/2021 1:46:10 AM • Pride Rally 3... • Answered on Aug 26, 2021
3answers
WHY IS MY SCOOTER BUCKING"? WHEN RIDING, THE
Yes the batteries will be failing and the brake will kick in automaticly
3/7/2018 5:22:26 AM • Pride Rally 3... • Answered on Mar 07, 2018
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
9/3/2017 8:41:05 PM • Pride Rally 3... • Answered on Sep 03, 2017
Scooter is old
My advice is to buy a good used one on ebay. There are some real bargains to be had! I really don't regret mine. If you have to travel to get one remember that even the good low cost airlines like Flybe carry scooters free of charge -you just need to ask in advance
6/3/2016 12:34:27 AM • Pride Rally 3... • Answered on Jun 03, 2016
The back left wheel lug (Center lug that holds the tire on) is spinning faster than the tire. The machine will not go forward very fast at all. Any ideas what would cause this, and how to fix it?
Hi if SOUNDS LIKE U MIGHT HAVE A BROKEN the axle KEY TAKE THE WHEEL OF & CHECK IF THE HALF MOON KEY IS OK....GOOD LUCK
3/8/2016 1:45:19 AM • Pride Rally 3... • Answered on Mar 08, 2016
Scooters manual
Pride's website has them
2/24/2015 6:05:19 AM • Pride Rally 3... • Answered on Feb 24, 2015
How to bypass key switch on pride legend side
While this can be done I do not suggest it. The lock out system is then overridden and the scooter can become dangerous. Also the charger and other electronics will not function correctly. Replacing the switch can be easily done. Parts can be obtained through monsterscooter.com
4/18/2014 7:47:55 PM • Pride Rally 3... • Answered on Apr 18, 2014
Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
4/11/2014 2:17:15 AM • Pride Rally 3... • Answered on Apr 11, 2014
Electrical diagram horn
charging problem
7/8/2013 7:35:21 AM • Pride Rally 3... • Answered on Jul 08, 2013
Need Charging Cord Only (Not the Battery)
I would check company web ste for information on the unit for a part number. Then check Ebay or any parts supplier that pops up on web. Good luck, Chas
8/12/2012 5:39:19 PM • Pride Rally 3... • Answered on Aug 12, 2012
Have purchased a used Rally
Bob,
The owner's manual can be downloaded at:
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
or at
http://manuals.monsterscooterparts.com/mobility/Pride/manual-pride-rally.pdf
The serial number is on the frame. On this model the SN may be on a tag under the rear cross frame OR remove the rear plastic cover under the seat and find the SN to the right of the seat post on the frame. Pride can run the SN with their SN decoder to give you the month and year of manufacture 1-800-800-8586.
The parts manuals are available if you have dealer access on line. You may be able to call Pride and have them send you a printed one. Hope this helps.
With a used scooter, you may have to invest in a set of 2 new U-1 batteries fairly soon. These are available locally and on-line at a big discount. They are simple to install. Hope this helps.
12/11/2010 11:23:40 PM • Pride Rally 3... • Answered on Dec 11, 2010
I have a pride rally 3 wheel scooter, a older
mcdevito75 here, You sjould be able to contact Pride Rally online, or visit any surgical supply outlet in your area.
6/26/2010 6:20:33 PM • Pride Rally 3... • Answered on Jun 26, 2010
WHERE ARE THE SO CALLED EXPERTS AT THIS SITE?
Hi. Do you have a problem? we are Pride, Invacare, Shoprider agents, and service all brands.We have a full list of faults for most scooters. ask away.Neil.
5/27/2010 6:03:27 AM • Pride Rally 3... • Answered on May 27, 2010
How do you get to the battery compartment
This should simply be a case of lifting the seat up and off (please be careful, they are quite heavy), then remove the rear plastic cover/shroud that id located directly beneath the seat. There should be two batteries located directly underneath this plastic cover. You may need to hold the seat rotation lever upwards to remove the seat. Hope that has helped.
4/7/2010 2:27:13 PM • Pride Rally 3... • Answered on Apr 07, 2010
Help please
hi , the following link will allow you to download a rally manual, if you require any more help please let me know.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Rally_shopper_om.pdf
Regards
GeWiz.
12/29/2009 5:16:39 PM • Pride Rally 3... • Answered on Dec 29, 2009
Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
11/25/2009 1:47:56 PM • Pride Rally 3... • Answered on Nov 25, 2009
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual. https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
4/20/2024 4:18:53 AM • Pride Health &... • Answered on Apr 20, 2024
2answers
Pride Go Chair, back wheels make noise when I go forward and reverse
It may be something as simple that you have picked up a twig or a piece of litter. Lie on the floor and look underneath with a flashlight or get a young person to do it..
3/5/2024 10:49:33 PM • Pride Health &... • Answered on Mar 05, 2024
Pride Rally 3 Wheel Scooter  Logo
25 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
ralley scooter batteries not old
  • Health & Beauty
