20 Most Recent
Elite Pride Go Go Traveller 3 Wheel Questions & Answers
How do I determine or - with 24 volts system/
it is 24v and the best way to do it would be direct to the batteries but with a switch to isolate it from the scooter controlls when charging to prevent damage to the scooter also you do not want to charge faster than 2 amps or you will kill the battery life
Scooter won,t move
Hi. Sounds like the motor brushes need attention. If you push the scooter when it wont move, does it suddenly jump forward. If so then its definitly the motor brushes. Good luck. Neil.
3 wheelers tip. Is there a stabilizing bar with 2
Hello, There is nothing available from the manufacterer or comercially for this type of scooter.
Some Scooters have Castor wheels underneath the edge of the footboards but they are usually have a higher ground clearence.
My go go elite scooter suddenly dies seems to
You might be over the weight capacity for this little scooter. When you overload it, the controller senses and overheating and slows the scooter down to prevent burning up the electrical system. When it has cooled, it will operate normally again. If you aren't overloading it, or if the previous owner did in case it's used, then the PC board needs to be replaced which is located inside the top of the tiller cover and the speed pot conects to this board. They aren't too expensive; about $30.00 from a Pride dealer. Take the shroud covering the tiller assembly apart by removing the screws that hold the clamshell cover together. Take the knob off the speed control and you will see an electronics board with several snap-on connections to it. This is what gets replaced.
Scooter wont work
may be the battery has been damaged. you will have to replace the battery.
My pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
Alarm shutting down scooter
I have never heard of this, and I just check the manuals to be sure. The only "Alarm" is the horn button. If that is going off while driving, I suspect that a wiring harness is frayed and shorting out.
