20 Most Recent
Pride Mobility Products Pride Celebrity XL - 4 Wheel HD Scooter Questions & Answers
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
