20 Most Recent
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Questions & Answers
Issue with Honda GX390 from Sams
hi
in my opinion there is nothing wrong with the rotor as you have 13.4volts at the brushes end . instead the rectify within in foulty
1/3/2018 12:03:28 AM •
Coleman...
Answered
on Jan 03, 2018
Technical Problem
Make sure you have adequate safe space outdoors to run the generator. In order to provide proper ventilation, some generators require 3-5’ distance on all sides of the generator – check your generator manual for specifics.
8/12/2012 3:12:20 AM •
Coleman...
Answered
on Aug 12, 2012
My Coleman Powermate 7000 won't
I not you said you "checked the oil level" My experience with most portable generators is that they must me positioned as level as possible and the oil level must be fully serviced as full as you can get it without oil leaking back out of the dip-stick hole on units WITHOUT an extended dip-stick. Unless those conditions are met the low oil level sensor ends up presenting a false low oil signal and it grounds out the ignition. DO you have Spark at all? If you do have spark and it still does not run respond with the MODEL number off of your ENGINE and I will show you where the main fuel jets are located so you can make sure the orifice is clean.
Some units have a fuel solenoid that presses into the main fuel jet recessed area and shut off the fuel to the carb. This is also an area that debris causes havoc.
Thanks,
Kelly
8/29/2011 4:24:59 AM •
Coleman...
Answered
on Aug 29, 2011
Where can I find the
you can find the parts nyou need at any lowes or home depot they will carry these parts if your by a tractor supply store try there to, good luck,
8/27/2011 3:15:33 PM •
Coleman...
Answered
on Aug 27, 2011
I purchased this 7000 watt
Since this is a brushless alternator type the generator FIELD exciation performed by the rotor and the output contol is provided via the capacitor that increases or decreases the size of the stator magnetic field.
With no output at all on a brushless generator the 2 components you look at are the cpacitor and the wiring / field loop continuity of the stator AFTER flashing the field.
Download this manual and go to page 88 of the pdf file for field flashing procedures. (you will be surprized)
Flash the field and try it again. Feel free to ask any future questions.
Thanks for choosing FixYa,
Kelly
8/2/2011 11:24:40 PM •
Coleman...
Answered
on Aug 02, 2011
