20 Most Recent HP Compaq 8510p Notebook Questions & Answers
Overheating hp
clean it no PC told all vents all fans all heat sinks and radiators. all lint gone vga card? not told, PCI slot or mainboard vga built in???? not told https://www.pcdied.com/overheated.html
5/1/2022 4:54:33 PM • HP Compaq 8510p... • Answered on May 01, 2022
2answers
Breaker/fuse on hp 8510p
There are no fuses that you can see on the outside of any laptop. They are on the motherboard and they are inside the battery itself. You need to give us more info or perhaps attach a picture of the issue and explain how you shorted what.
11/13/2017 12:03:37 PM • HP Compaq 8510p... • Answered on Nov 13, 2017
Drivers for dell optiflex 745 windows 7
This is mostly a true answer: You can use Windows Vista 64-bit drivers in a new Windows 7 setup...There are a few exceptions, from what I've discovered: Several types of HD Audio drivers will not cooperate, and some WIFI drivers won't either. Here is a link to get the Dell Windows Vista x64 drivers to get you started: http://www.dell.com/support/home/us/en/19/product-support/product/optiplex-745/drivers I hope this helps a little...
8/8/2014 6:13:07 PM • HP Compaq 8510p... • Answered on Aug 08, 2014
Cannot connect to internet.
This is usually because the wireless key code (password) was entered incorrectly or has got corrupted. Go to "view wireless networks" (from the icon at bottom right of your screen) find the one it says it is connected to and click "disconnect". Then re-boot the PC (not strictly necessary but a good precaution), go back to "view wireless networks", find the correct one for your router and connect to that with the correct code key. I have seen it where the code key has been changed from the one written on the sticker on the router and if that is the case the "fix" will be more complicated.
Also, if this does not work, go to "control panel" then "Internet options" and then "advanced" and find and click on "reset". This puts Internet Explorer back to the default settings and often fixes it (though NOT if yours is an incorrect wireless key issue as talked about above) - Your home page will change to MSN but that is easy to change to your preference.
Hope this helps
John B
8/8/2014 5:42:25 PM • HP Compaq 8510p... • Answered on Aug 08, 2014
Please help.... I can't get any further with
for this you have to reset the bios setting but unplug the bios battery from your laptop and the same time also eject the lap battery
5/23/2014 1:55:36 PM • HP Compaq 8510p... • Answered on May 23, 2014
Wi-fi not working
Use an external USB WiFi adapter. I prefer to use nano (very small) Edimax WiFi adapter. It cost less than $15
3/1/2014 12:50:55 AM • HP Compaq 8510p... • Answered on Mar 01, 2014
Password power-on reset
you need recovery disc ,you should be able to override all passwords .if your laptop or PC is new ,then one should have it with your operating manual .if not you will need to get one .which you can pick up from most reputable providers .if you have genuine windows contact them and they can send a cd .
11/14/2013 8:32:43 PM • HP Compaq 8510p... • Answered on Nov 14, 2013
Fn symbols f8
it's to put your laptop in safe,mode at start up ,as soon as you switch on ,hit f8 continued and follow instructions .only needed when you have problems ,otherwise ignore it ..that's what I think ..but each system works different ..I may stand corrected ..hope it helped
11/14/2013 8:23:00 PM • HP Compaq 8510p... • Answered on Nov 14, 2013
manual
How do I disable tapping on touchpad?
A. . Please hold down F1 key and hit F12 keys together.B. Please download, install touchfreeze: http://code.google.com/p/touchfreeze/
6/3/2013 3:40:53 PM • HP Compaq 8510p... • Answered on Jun 03, 2013
Hard
  1. Open the cover that is over your HDD
  2. Remove the Hard Drive from it's casing
  3. Now replace the HDD ensure everything is connected properly
  4. If possible, power up and listen for the HDD to spin, if it's making no noise or a very noticeable clicking noise it's time to purchase a new HDD
  5. If not power on anyway and see if you get the same error.
  6. Try a spare HDD instead, this would indicate if the HDD you have now has failed also
Let me know how you get on
5/31/2013 11:50:46 AM • HP Compaq 8510p... • Answered on May 31, 2013
Fix broken hdmi port
Contact your system's manufacturer, if its under warranty it will get replaced.
5/16/2013 10:12:28 AM • HP Compaq 8510p... • Answered on May 16, 2013
2answers
How to clear bios password
hello sir ... enter 3 time wrong password then u will see a code like this CNU1234ABC send me code ill wil send u master password Thanks
4/7/2013 6:31:29 PM • HP Compaq 8510p... • Answered on Apr 07, 2013
How to enable wifi on compaq
Hello, how are you doing? you dont need to panic you are at the right place. i will give you some solutions that will enable you to fix your pc. i have some questions to ask you firstly.have you been using the wifi before?is the computer a new one?did you reformat your computer?please get back to me with answers to this questions to enable me give you and adequate reply.thanks
12/26/2012 7:48:48 PM • HP Compaq 8510p... • Answered on Dec 26, 2012
Problem with HP 8510q laptop charging. Charging not working. Laptop working only that time when i have power in battery. Charging light not show. I try other charger but same problem. Is it inside som
Inside? Yes. (If 'charger' is good)Fuse?NoDiagnostic flowchart:A) AC adapter (Charger), has to be KNOWN to be good, before going on.Used on a working laptop to see, or multimeter is used to check Voltage (DC)The plug end that goes to the laptop, from the AC adapter, has a Center Hole, and a cylindrical outside metal shell.The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.If more than one DC Voltage scale, the Function knob is set to the 0-50 Volt DC scale.The Positive (Red) probe lead of the multimeter goes to the Center Hole, and the Negative (Black) probe lead of the multimeter, goes to the cylindrical outside metal shell.You should be reading 19 Volts DC.Also have an assistant gently wiggle the cable FROM AC adapter TO laptop, and the power cable TO AC adapter.If there is a fluctuation on the reading, there is a broken wire, or wires, in one of those cables.B) Check the DC Power Jack.This is the jack on the laptop (DC_IN) that the AC adapter plugs into.Has a Center Pin, and an inner cylindrical metal shell.Battery removed, use an eraser on the end of a No.2 pencil, and see if you can GENTLY wiggle the Center Pin around.ANY perceptible movement of the CENTER PIN, means replacing the DC Power Jack,(By the way, is it an 8510p, or 8510w?)http://www.alldcjacks.com/en/ppj052-laptop-dc-power-jack.htmlAny movement of the rest of the DC Power Jack (Body), means replacing it; or may just mean the solder joints are cracked, and can be re-soldered.C) AC adapter and DC Power Jack checks out?Problem may be with Power MOSFET's on the motherboard, and associated MLCC's.(Multi-Layer Ceramic Capacitor, and they are SMD/SMT just like the Power MOSFET's.Surface Mount Device/ Surface Mount Technology)Using HP pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's, for an example,http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.htmlOr, it could be worse,http://koti.kapsi.fi/jpa/stuff/pix/travelmate_6292/Regards,joecoolvette
12/26/2012 10:14:21 AM • HP Compaq 8510p... • Answered on Dec 26, 2012
Power-on password on hp 8510p
Power On Password & Hard Disk Password With your next laptop you should protect it with a Power On Password AND put a password on your hard disk. This will stop anyone from using your laptop and if they move the hard disk from your laptop to another laptop they cannot access the data on your hard disk with the hard disk password. BUT you need to write down or remember these passwords; if you lose or forget them you cannot gain access to your laptop. There are no backdoor passwords to remove these passwords. To set up or change these passwords, go to the BIOS configuration - then security configuration. http://techtips.salon.com/reset-hp-laptop-bios-password-1476.html
11/27/2012 7:35:13 AM • HP Compaq 8510p... • Answered on Nov 27, 2012
Plugged in but not charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
10/14/2012 7:39:19 AM • HP Compaq 8510p... • Answered on Oct 14, 2012
2answers
Is there a wireless hardswitch somewhere on HP Compaq 8510p
There is a wireless button the computer..
Its couple of inches beside the power key...
or the place where we have the HP logo...down below that there would be wireless Button/LED
Hope this works
Regards
KEN
10/13/2012 7:02:28 PM • HP Compaq 8510p... • Answered on Oct 13, 2012
HP Compaq 8510p Notebook Logo
80 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
activate webcam
  • Computers & Internet
