20 Most Recent
Nokia E71 Smartphone Questions & Answers
Waiting for GPS comes up when I try to get
what are you using for gps? ovi maps? garmin? google maps?
i suggest installing google maps to see if your gps is working alright.
then check in phone settings to ensure that gps positioning method is enabled for 'built-in gps' and 'assisted gps', thereafter check positioning server is set to 'supl.nokia.com'.
normal lock time is around 5-30seconds with E71 GPS with A-GPS on; anything more than that i'd attribute it to a faulty built-in gps unit.
let me know if it works.
10/18/2021 6:40:02 PM •
Nokia E71...
Answered
on Oct 18, 2021
How to unlock nokia e71 from vodafone network,
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try these WEB sites :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
1/11/2021 4:22:39 PM •
Nokia E71...
Answered
on Jan 11, 2021
Nokia e71 lock code
press the keey on the left side of shift key. it will change the entry into num mode. press 112 and press dial button (green phone button). It will show connecting press end call button. Now the set should be in normal mode.
4/18/2020 8:59:28 AM •
Nokia E71...
Answered
on Apr 18, 2020
How to use front camera in my nokia E71 phone ??
I am not familiar with that specific phone, but when you open the camera app on most phones there is a button that is a picture of a camera with curved arrows pointing left and right. That button switches from back to front and vice versa.
8/19/2019 11:49:02 AM •
Nokia E71...
Answered
on Aug 19, 2019
I opened a pdf file
Navigate to file manager, open documents folder and you should be able to locate the PDF file if you would closely look at all the files in there one by one.
Another option is to open the downloads folder within file manager and look inside, you should be able to identify the file in question
Last option is while within file manager, type into the search box ".pdf" (a dot followed by the letters PDF; a without the semicolons)
This should bring up/call out all PDF files inside your device; scan through to identify and in turn delete the corrupt PDF file
10/13/2017 2:48:57 PM •
Nokia E71...
Answered
on Oct 13, 2017
