20 Most Recent
Peg Perego Gaucho Rock'in Questions & Answers
Peg Perego Gaucho 12v has will not run
Check the wires to accelerator switch and the switch itself. I had problems where the switch has a high resistance when checked with a meter. When the switch is depressed, it should only read a few ohms. Any higher, it should be replaced.
We have peg perego Gaucho,gear
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
How can upgrade my
you would need 24 volt motors and the circuit board, and shifter switch, and foot pedal switches
Peg pergo gaucho jeep won't go when push
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, then check for power at the foot pedal, then at the shifter, then at the motors
Relay clicking
probably got a bad motor, are both rear wheels spinning in all of the gears?
