20 Most Recent
Chamberlain 950CB Remote Control Questions & Answers
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Paper instructions
Ask a friend to search for the instructions and print them for you. You may also be able to go to the library and use a computer there to do this on your own.
How do i fix garage door that wont open or close?
You have to make sure the trolley on the drive engages with the catch on the door. You may have to lift the door to the point it will engage while you are running the trolley in the close mode. Check that the trolley latch is open and ready to engage the catch. There is usually a rope to pull on to do this.
I need to reprogram my old LiftMaster opener,
Not sure if you have deep switch or smart learn button. In first situation you need to change the sequence, in the other, pressing the learn button for more then 30 sec should reset and erase all remotes from opener memory..
