20 Most Recent
Toshiba Satellite A215-S5837 Laptop Questions & Answers
My laptop shows a blank
try to connect your vga of your laptop into any monitors.
if it still wont boot-up, possible error would be the processor or motherboard of your laptop.
ask a technician near on your place that could open your laptop and test the memory, and even as well as the processor..
8/23/2011 8:18:56 AM •
Toshiba...
Answered
on Aug 23, 2011
WHEN BOOTING THE TOSHIBA SATELLITE
These beeps are error code and two short beeps during start up normally refers to RAM or memory not being detected. You can try to reseat the RAM modules or ask someone who knows how to do it. If it will still be the same, it means that the RAM is defective and consider replacing it.
Cheers!
4/7/2011 6:16:40 AM •
Toshiba...
Answered
on Apr 07, 2011
I have a Toshiba Satellite A215-S7444. Recurring
The little icon on the task bar is not always an accurate and reliable indicator of the status of your connection. If you are having occasional dropouts of signal, try repositioning your laptop either closer to the wireless transmitter or in a more direct, line-of-sight position. Sometimes it becomes necessary to install a wireless "extender" which boosts the signal to enable you to stay connected, especially if there are several other wireless networks within range of your machine.
1/7/2010 10:08:22 PM •
Toshiba...
Answered
on Jan 07, 2010
Battery is not charging when plugged in
fiddle with the power cable when in the back of the laptop if no light comes on saying the cable is in then you need new cable or new port or if the cable powers the laptop but the laptop battery is generally wont hold its charge n dies then you need a new bettery
8/31/2009 3:53:02 PM •
Toshiba...
Answered
on Aug 31, 2009
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM •
Toshiba...
Answered
on Feb 22, 2023
My toshiba laptop displays an expected error occured. Error Code 0xc0000034 during booting window
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
2/3/2023 11:39:14 PM •
Toshiba...
Answered
on Feb 03, 2023
