20 Most Recent Toshiba Satellite A305-S6857 Laptop Questions & Answers
Laptop shuts down when connected to AC adapter
NEC token capiciter
9/9/2013 10:56:58 PM • Toshiba... • Answered on Sep 09, 2013
7answers
My Toshiba Satellite A305-S6858 keeps restarting
On the computer manager, go to the device manager and disable the processors. It worked for me like a charm after several attempts to restore it to original settings and formatting the hard drive. It doesn't affect performance, it seems to be more a failure of the drivers than the hardware.
8/19/2012 7:59:42 AM • Toshiba... • Answered on Aug 19, 2012
My A305-S6857 freeze every time when I tried to login..
Try doing a startup repair by pressing F8 repeatedly on startup. On the options menu, choose 'repair my computer'. If this isn't successful you can try running your antivirus software in safe mode to check for any infections. Press F8 as before and choose safe mode. If this works, you can also check your event viewer to see if there are any system errors recorded: control panel>system and security>administrative tools>event viewer. Expand the critical and error menus under 'summary of administrative events' You can double click on an event for further detail and the event ID which may help you troubleshoot the problem further.
4/3/2012 10:34:47 AM • Toshiba... • Answered on Apr 03, 2012
My toshiba satellite a305-s6857 powers
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes.Choosing no will start doing a system restore.
You need to go to start>control panel >system> advanced>start up and recovery>and clear automatically restart.I hope this helps you.Thank You & good luck.
5/18/2011 2:04:15 AM • Toshiba... • Answered on May 18, 2011
When I plug in the charger , it charges the
like the m200 problem maybe the power management system on bios you can try to disable the proseccor the upper procecor on device management . o to save mod open device manager disable the upper proceccor tan restart hope this can help u
5/11/2011 8:10:39 PM • Toshiba... • Answered on May 11, 2011
2answers
The toshiba laptop A305-S6872 power
My Toshiba A305-S6872 laptop is OVER HEAT UPTO 45degree centigrade so what can i do the fan is working.
4/15/2011 7:22:44 AM • Toshiba... • Answered on Apr 15, 2011
I need help with accessing
go to toshibas website and download the original software for your laptop.
3/22/2011 1:47:01 AM • Toshiba... • Answered on Mar 22, 2011
My charger in not connection
if charger light is ok. then the problem with the power connector on your laptop motherboard. you have to change it with any motherborad repairer. thank you and keep smiling
1/14/2011 9:24:10 PM • Toshiba... • Answered on Jan 14, 2011
My a305-s6857 webcam wont work.
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
1/7/2011 7:52:30 AM • Toshiba... • Answered on Jan 07, 2011
Toshiba satellite A305-S6857 - how to replace the
Replacing the DC Power Jack on this model of Toshiba Satellite A300 series, is SWEET!
{The Toshiba Satellite A305-S6857 Notebook PC, is part of the Toshiba Satellite A300 series of Notebook PC's}
No de-soldering, or soldering is needed.
The DC Power Jack is a DC Power Jack Harness.
The DC Power Jack is connected to a cable (Wires) that end in a connector, and the connector plugs into the motherboard.
To repair the problem you just replace the power jack harness.
A) Guidance given with instructions, and a pictorial guide, (Click on each photo to enlarge),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/laptop-disassembly-process-1.htm
The above is Page 1.
To go to Page 2, and Page 3 ,click on the white page number at the top, or bottom of the page.
{Page 1::Page2::Page 3::Find another model }
Page 2, Step 17 shows you the DC Power Jack Harness, and where it connects on the motherboard. (Small white rectangular connector)
B) This is a link to a free Service Manual for the Toshiba Satellite A300 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the 11th line. The one that starts with Satellite A10.
Scroll across, and click on > A300
This is a PDF file.
Allow up to 30 seconds after you click on the file name A300, for the first page to come up.
It may also take additional time for the file to fully download.
C) Remove ALL power to the laptop before you begin.
Remove the AC adapter (Charger) and Battery
D) Observe Anti-Static Precautions
It is Advised to buy and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
{For one example I connect the alligator clip to the metal frame of an empty desktop computer case}
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
Using an ESD wrist strap, and connecting to a good ground source, will relieve your body of Static, and help to ensure your laptop is safe from Static shock.
E) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screw/s come out of.
There may be as many as 60 screws, and 12 different types.
Do NOT mix them up!
If no multi-compartment container is available, you can substitute with a clean egg carton.
Mark each egg holder.
F) Make a record as you disassemble. It's nice to have a record you can go back to in case you are interrupted, and to have a record that YOU understand.
Make notes and drawings, use a camera, or video cam if available.
{Use Good lighting}
From a quick search,
1) http://compare.ebay.com/like/170510661911?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=184497530091&crlp=1_263602_309572&UA=WXF%3F&GUID=e35d70b712c0a0aa14823c52ff69e46d&itemid=170510661911&ff4=263602_309572
Another one,
2) http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3231&zenid=90f1860bdc1b624a9122b76394734645
Regards,
joecoolvette
12/14/2010 5:39:16 AM • Toshiba... • Answered on Dec 14, 2010
My computer Toshiba laptop turns on, but the
your monitor has died and will need to be replaced
Robb
9/24/2010 2:37:26 PM • Toshiba... • Answered on Sep 24, 2010
Hi is there any special procedure ro bios recovery
Here is a helpful guide. Scroll to the first person's response. http://social.technet.microsoft.com/Forums/en/itprovistadeployment/thread/022386ba-a445-44ba-97f7-d8ba4b6cc54b
-CompDoctor
2/13/2010 11:06:49 PM • Toshiba... • Answered on Feb 13, 2010
Camera for my toshiba is not turning on
There is a Fn button located at the bottom left corner of your keyboard.......press this along with the F6 key to switch your camera on and off.
11/8/2009 1:33:29 AM • Toshiba... • Answered on Nov 08, 2009
2answers
My computer keeps freezing
it could be a number of issues. Over heating, faulty memory, or other fault.
to improve the airflow in your latop use canned air to blow dust out form the fan and the holes that the laptop has.
Memory could be tested with a memory testing software.
http://www.memtest.org/#downiso
this software is started from a cd or a floppy, it needs to be burned into a cd or written into a floppy
http://www.ntfs.com/iso-burning.htm
the computer needs to start the cd to run the test, to start from the cd, look at the screen when powering the computer up, it will say on some part of the screen to press Button to enter bios or boot menu, if you see boot menu press on that button when the message is shown and ones you are on the boot menu select the cd drive and press enter to start from it.
if you don't then you would need to edit the boot order in the bios
here's info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
let me know how the memory test goes.
If the test is OK and no errors come up, then I would suggest that you do a fresh installation of windows to your computer from either the windows xp installation cd or the recovery discs that may have come with the laptop.
7/1/2009 7:29:36 PM • Toshiba... • Answered on Jul 01, 2009
What is the best way to clean my laptop screen
get some Static free cleaning sheets , they look like dryer sheets but they are made for cleaning such screens
4/12/2009 8:21:35 PM • Toshiba... • Answered on Apr 12, 2009
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
Toshiba Satellite A305-S6857 Laptop Logo
32 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite a305 s6858 keeps
  • Computers & Internet
