20 Most Recent
Nokia 6085 Cellular Phone Questions & Answers
I forgot password of my microsd card it's urgent
This solution for Phone that have execution file name : unlockMMC.app on folder z:\system\app\
Note :
Not all S60 Phone have this execution file.
To unlock Memory Card :
- Run execution file unlockMMC.app
- Enter new Password you like (example "12345")
- Run app Memory (Phone app Memory Standard)
- Choose To Unlock MMC with that new password
2------------------
Every times you set to lock ur Memory Card with lock password , phone made a file to save your password with file name mmcstore - you can find ths file in folder c:\system\.
Note :
To see the file you must set ur file browser app to show hidden files.
To get your Lock Password :
- Send that file into your PC
- Change file extension with .txt
- Open that file using app Notepad
- You will see your lock password
or
(This way not always success)
- Make sure that your phone have app Notepad
- Copy that file into other folder
- Change its attribute not a system file and not a hidden file
- Change its extension with .txt
- Run app Notepad on your Phone
- Open that file
3------------------------
Use app for Break Memory Card Password - this app name MMCPWD
You can find this app using this link :
http://imserba.com/index.php?name=PNphp ... ;start=360
- Install app MMCPWD into your phone
- Run app MMCPWD
- Choose Option then choose Restore
If u like my post please rate me. I really need some good ratings. Thanks
My phone is hang off
Remove the memory card and battery , check the card for corrupt files, if so format the card . Now reinsert the battery back to the phone and restart, If the phone hangs then the software is faulty and needs a re-installation.
Contact Nokia care for estimate and genuine software.
Net work covereg e nokia 6085
NO NETWORK:First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
How to enter puk code
Sir the PUK code is provided by your service operator, contact the customer support of your service provider via another mobile which has same service provider you are using.
They might ask for your personal details & the whole process will take around 2-3 minutes.
Hi" all brothers my nokia 6085 gprs is not can
Hi, you are just resetting the setting of your mobile by typing *#7780# instead of freeing up memory of your phone by deleting some files. You can also format your phone by going in the settings option and select restore factory setting and select the option reset all. This will format your phone but you need to backup your contacts and any important files before doing this.
Unlock nokia 6085
Hi, You can unlock a Nokia 6085 safer and easier using unlock code. You can visit
www.superunlockcodes.com to get the unlock code for your Nokia 6085. This site provides unlock codes for most of the international network. ensure that your network is available in the supported networks list.
Does not ring
My Dear Your Phone Ringer DefaultSo Please change Ringer and Ringin Sound Problem will solved
Phone does not ring
mY dear Your Phone Ringer Default So Please change RingerAnd Ringing Sound Problem will solved
