20 Most Recent
LG U400 Cellular Phone Questions & Answers
Lock unlock
Do you want to unlock your phone from Network lock?If it is,So,then you can get unlock your LG U400 phone using unlock code for the site
MobileUnlockSolutions.com
like here you need to specify your country, Network name to
which it is locked, IMEI number of your phone. Then they deliver unlock code to
you through mail with unlocking instructions. By using this you can unlock your
phone easily.
Lg u 400 usim blocked then how i shoul it unlock
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Not open line?
I will help to Openline the LG U400 from network lock..It's locked to which country,network?You can get the unlock code from the site
Theunlockarena.com/lg-u400/rs13wp9/ and unlock it easily...Then use with other GSM Network sim card.
MY PHONE LG U400 DOES
Hii
display problem is related with screen
Might be your software problem get once FLASHED your handset and if then also same occurs you need to change you display.
Thanks
Imei 359286000008476 unlock code
http://www.ehow.com/how_6956571_unlock-lg-u400-mobile-phone.html
The above link will guide you through the process.
You will need to buy an unlock code, however.
Death
The LG U400, nicknamed the Neo, is a 3G
music phone available exclusively on the 3 network. The U400 has an unusual and
distinctive slide design. Despite a smart black and silver finish, and cool blue
detailing, it's an ugly beast, mainly because of the large jog wheel located
off-centre, with call buttons to the side. The jog wheel is very useful,
however, enabling control of the music functions when the phone is closed. With
a chunky feel and uncompromising looks, this is a phone with a very masculine
style
Keeps saying usim locked
hello there....well its quite simple...there is nothing wrong with your phone ...its your SIM... if it is asking for a PUK (Personal Unblocking Key) code...call your subscriber and ask them for PUK code,entering this code will reset your sim
if u keep entering wrong your sim will be damaged so call them
If the error message is saying sim damaged call them and ask for a "sim replacement" you will get a new sim while you will retain the same number ,however you will lose the phone numbers and other data stored in sim,this can be free but it depends on the company and how 'customer friendly they are
Hope this helps
Cheers
Driver for LG KG195 mobile set
If you're trying to use the phone as a modem call your carrier most companies need to add a plan to the account to use phone as modem features.
Usb draver for lg u400
you can download the lg u400 usb driver for free from the given link,
http://www.nodevice.com/driver/u400/get41520.html
