20 Most Recent
Goldstar R5050 Air Conditioner Questions & Answers
How do i get the freeon in the ac
Air Conditioners don't 'Use' freon per se. A common fallacy is the thinking that if "It's not getting cold, then it needs freon." If your unit lost freon, it has a leak and adding freon will only be a very short term fix.
If you're certain that you need freon, you'll have to take the unit to a certified HVAC technician. EPA regulations make it nearly impossible for the average handyman to service A/C units, since the freon must be handled in a very specific way with equipment not generally available to the average owner, was well as R-12 freon gas which can be bought only by licensed HVAC technicians.
However, there are many other problems that are far more likely to be the cause of no cooling than loss of freon. It could be something as simple as dirty condenser coils (you'd be surprised how common it is that a simple cleaning of these coils will 'fix' a non-working window A/C), to a defective thermostat switch, to other defective switches/controls.
Unless it's a very obvious leak, I always suspect a loss of freon LAST on my list of possible cause of non-cooling in these units.
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
With the unit running, the unit sounds as if water
This is usual But be certian that the unit is tilted enough also check filter and clean it while your at it . then check drain . you might have some dirt around the drain . if so clean it and add a bit of clorox a tiny bit ony to the drain let me know
Hi, I have Gold start
your problem is cable try insulate with electrical tape the damage portion of your aircon cord if you want to replace cable please state how much horse power and voltage use.
