20 Most Recent
Nokia BNIB NOKIA 3500 Classic Unlocked/Sim Free BLACK/RED UK Cellular Phone Questions & Answers
Operation failed in bluetooth of nokia 3500
Please remove the paired device from nokia 3500 you are dealing with and restart your phone.
Again pair it and start receiving files. It is always a good practice when you receive a file from other device you always be on main screen of your phone not in bluetooth settings. I have seen phone with different operating system scause problem while receiving files when you are in bluetooth settings.
Hope this helps you.
How to lock the message folder in nokia 3500c
There is no direct option provided by Nokia to lock the message folders. But you can protect unauthorized use of your mobile by providing keypad lock with security code. Some Java mobile application were also available to hide the messages from inbox.
HI,
I am from Mauritius and
You can do it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your
mobile is not an CDMA mobile , you can get the network unlock code(NCK) by
just contacting the current network provider customer care
department.It is free of cost.
How can i recover my memory card password of nokia
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
- go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
- Now open the file in notepad ,
- No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Need restriction code for opening Nokia BL-4S Please
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try these WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
