20 Most Recent
Peavey Pv 2600 Power Amplifier Questions & Answers
What is the replacement of transistor d1915
IS that a 2SD1915 or something else, it looks like an 2SA1022 or NTE2407crosses - Newark Electronics or Mouser might be able to provide you a different cross reference. There are data sheets that seem to indicate a A1022 / NTE 2407 - this one can be found here
http://www.mouser.com/Search/Refine.aspx?Keyword=2SA1022 Amplifier Transistor - these are common I think for older amplifiers. If memory serves me right - I probably have a couple old ones I bought to fix a Reel to Reel .
How to connect subs and mains to the same pv2600
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF'
If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output.
If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
Can one(1) Peavy PV 2600 amp provide enough power
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
One side stopped workig on
Hi,Please be advice that the center output connector is only for BRIDGE mode operation, you should not use that way, try to clean all the back switches with a cleaning solution spray, clean all switches and check amp functionality again in stereo mode.
My pv2000 amp stop working on one side
Please add more background, which channel stop working?As a blind advice, try to clean ALL back switches, including Stereo/Bridge Switch, let me know your results.
Why my amp is protecting after 4 hours
Soft start relay circuitry fail, take apart the top plate and when you turn the amp on check for a "Click" in the power supply relay, if not there's your issue.
