20 Most Recent
Toshiba Satellite U305-S2804 Laptop Questions & Answers
My laptop screen fades away after a couple minutes
This is a standard feature, it does this to save the battery. Go to Start > Control Panel > Display, and click on "Screen Saver". There is an option here of how long it will wait before the screen saver comes up (which may be set to blank). Then go into Start > Control Panel > Power Options and set the scheme or monitor to turn off at your specified interval.If these are not the problem, we will need your model number. Refer to your PC's documentation to find out how to change vendor settings, which is most likely done as a "hot key" (usually present as an alternate option on the fuinction keys).
1/13/2013 1:00:44 AM •
Toshiba...
Answered
on Jan 13, 2013
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
1/5/2013 12:36:39 AM •
Toshiba...
Answered
on Jan 05, 2013
Mute stay on and their no audio
There are two solutions available, therein; 1. Check your audio driver, if not installed please reinstall.2. Take the properties of Audio and then uncheck all checks. If the problem resist, must contact me back :)Good Luck
8/14/2012 5:40:26 AM •
Toshiba...
Answered
on Aug 14, 2012
No audio
Have you recently formatted your Laptop? if yes then check for your
driver? is your sound driver up-to-date? if not then install the latest
driver. if your sound driver is fine then connect a external Speaker and
see find out if you can hear the sound.
If no then check in your BIOS, Is your On board Sound is enable?
If all the above is fine then there might be some problem with your laptop speaker or on the board.
8/13/2012 8:16:28 PM •
Toshiba...
Answered
on Aug 13, 2012
My DVD player on my
Unplug from the mains and then remove the battery. Leave for ten minutes then put the battery back on. If it still does not work then it has had it. turn it over so you can access the underside and locate the one screw that holds the drive to the chassis. remove the screw and the drive will slide out. Take the drive to a computer shop and buy a replacement. refit in reverse and all will be well.
4/23/2011 9:21:11 PM •
Toshiba...
Answered
on Apr 23, 2011
No sound
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
don
2/16/2011 6:53:18 PM •
Toshiba...
Answered
on Feb 16, 2011
Toshiba Satellite U305-S2808 DVD replacement?
Optical drive removal varies among notebooks. Some have quick-release gadgets, which may be on the bottom of the notebook or in the memory compartment. Some have screws that need to be removed from the notebook bottom. On my Satellite Pro 6000, it's on the bottom, aligned with the drive, but halfway to the other side of the case. If this is the case, pop it out. Get the model number off of the drive; you may have to replace it with the same one. While most optical drive chassis are standard, the drawer fronts are different, and not necessarily exchangeable.
3/4/2009 10:16:23 AM •
Toshiba...
Answered
on Mar 04, 2009
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
2/16/2009 9:31:12 PM •
Toshiba...
Answered
on Feb 16, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
