20 Most Recent
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Questions & Answers
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Green light blinking on mr
It works for a about a minute and then the light blinking begins and it shuts off? What would be the most likely problem?
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Black flakes coming out
Likely the liner of the duct. Possibly a poor seem that is peeling up, possibly a rodent has gotten inside and chewed up some of the pieces. Either way, yes, more money. Possibly needs a duct cleaning, maybe some new duct, tough one. Best Wishes!! If you need further help, reach me via phone at
https://www.6ya.com/expert/thomas_092728000e6acb79
Mitsubishi mr. slim is leaking water
you dont have enough fall creating a water trap which breeds bacteria into a green slim ball blocking drain you need to chop more brick wood what ever the pipe drain go through so there is very good fall problem solved the pipe being blocked causes water to back up these heads can loose 4 ltrs an hr in qld not sure on other state hope i was some help
regards john
[email protected]topnotchelectrics.com.au
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
How do i Turn off the beeping sound from mr slim
It requires surgery to remove the beeper :) seriously, find a local nerd to go in, not hard to do, and yank out the little piezo buzzer. I've had customer that wanted the same, factory said sorry no dice.
Water dripping out of Mr.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
