20 Most Recent HP Photosmart C7280 Laser Printer Questions & Answers
2answers
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
9/25/2022 11:29:45 PM • HP Photosmart... • Answered on Sep 25, 2022
I have a HP Photosmart
There may be nothing you can do about it. A lot of the HP printers make a lot of noise as they start up or prepare to print. Has your printer always made this noise or did it just start?
4/6/2022 1:06:59 AM • HP Photosmart... • Answered on Apr 06, 2022
13answers
Prints extra blank page for every one page of printed material BEWARE SPAM NUMBER 1-800-532-4187
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
2/11/2021 12:05:07 PM • HP Photosmart... • Answered on Feb 11, 2021
3answers
I have a hp photosmart c7200 all-in-printer and
Have you run the Wireless setup wizard from Printer ? If No, Press Setup button on printer front panel - Scroll till Wireless/Network settings - Choose Wireless setup Wizard and follow the directions.
After you have setup printer on network - Run the Printer s/w disk and Choose Add a Device and Choose Wired/Wireless network and continue with the Installation screen.
6/1/2020 4:52:02 AM • HP Photosmart... • Answered on Jun 01, 2020
Hp Photosmart C7280 All-in-One doesn't print
Sorry, this isn't ASAP, but here's a solution on HP's website.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=3204785
The most important part of this is taking off the rear door / duplexer and cleaning the two rollers that you can just see inside the printer with the back off. Those two rollers inside the back of the printer (not the ones in the door or the ones hanging out the back when you take off the rear door) are the ones that pick up the paper and feed it up into the printer. Those rollers are hard to get to - long qtips are strongly suggested. If those get rollers dust or gunk on them, they get smooth and don't pick up paper as well.
Click the link for detailed instructions - don't just go with my summary of the solution.
11/19/2019 8:36:33 PM • HP Photosmart... • Answered on Nov 19, 2019
My HP C7200 printer keeps saying out of paper.
Usually when this happens you need to clean the rollers that pick up the paper from your paper tray. This video shows you how to fix that...
11/19/2019 8:30:11 PM • HP Photosmart... • Answered on Nov 19, 2019
2answers
HP Photosmart C7280 All-in one says "out of paper".
If you get an 'out of paper' message when you do have paper loaded, this video will help. Following the steps of this video, you'll see if there's paper jammed in the printer.
11/19/2019 8:22:55 PM • HP Photosmart... • Answered on Nov 19, 2019
3answers
Hope this helps! ">
9/7/2018 6:13:44 AM • HP Photosmart... • Answered on Sep 07, 2018
2answers
0XC05D1281
0XC05D1281 Problem with the HP Photosmart C7280 Laser Printer 0XC05D1281 Help me
9/7/2018 5:50:06 AM • HP Photosmart... • Answered on Sep 07, 2018
2answers
Hp c7280 printhead removal
my c7280 prints anything magenta in yellow meanwhile i have a lot of magenta ink and i have not mixed ink colours too...anything magenta prints yellow.
any help in resolving this pls?
6/12/2018 5:42:59 AM • HP Photosmart... • Answered on Jun 12, 2018
My HP C-7250 printer is
sorry not sure but I have some problem so your not alone it not just your printer
3/6/2018 12:54:21 AM • HP Photosmart... • Answered on Mar 06, 2018
Ink failure
put ink cartridges in the printer
7/20/2017 9:36:14 PM • HP Photosmart... • Answered on Jul 20, 2017
2answers
I am installing a hp
Download latest driver bundle (198mb) and the network reliabilty patch. Install the HP software choosing Connected via USB. Install the network reliability patch from the C7280 downloads page. Re-run the 198mb installer and choose Add a Device.
Presto! Wireless setup completes correctly.
11/14/2016 12:25:23 PM • HP Photosmart... • Answered on Nov 14, 2016
I am trying to scan
In Adobe Acrobat:-
From 'File' select 'Create PDF', 'from Scanner'.
Scan the first page and the program will ask of you for 'Next' or 'Done'.
Select 'Next' until you have scanned the last page, then select 'Done'.
You can also make the document searchable by carrying out an OCR on it under 'Documents', 'Recognise text under OCR', 'Start'.
12/5/2015 7:22:28 AM • HP Photosmart... • Answered on Dec 05, 2015
2answers
My HP C7280 prints a blank page after every printed page
Here's your solution. Good Luck!
7/9/2015 5:21:20 PM • HP Photosmart... • Answered on Jul 09, 2015
HP Photosmart C7280 Laser Printer Logo
335 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp c7200 printer keeps saying out paper
  • Office Equipment & Supplies
