20 Most Recent Brother MFC 7840W Printer Questions & Answers
Brother mfc9970cdw printer offline error
Brother Printer Offline Windows 10 is a printer issue that you might have experienced one or more times when using your Brother printer. I wanted to add this, as I have seen a lot of concerns about this note of failure. Brother Printer Offline Windows 10 typically refers to an issue with the printhead and an error message will show on the screen. As a signal of this Offline Windows 10, the lights will keep on blinking. Caused by any foreign trash inside the printer rollers or due to printer paper jam and many more reasons for PCs. Solutions of Brother Printer Offline Windows 10. 1. Check all the wires are attached. USB connectivity of the printer wants to be perfect. 2. Check jammed papers because printers also go offline due to paper jamming. 3. Defective systems and hardware and outdated operators Blog- Brother Printer Offline Windows 10
2/2/2022 8:23:14 PM • Brother MFC... • Answered on Feb 02, 2022
5answers
Why does my Brother printer
I have copied in the illustrated instructions for resolving printer status is Offline or Paused. (For Windows®) but if distorted please view here.
The printer status is Offline or Paused. (For Windows®)
Description:
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Note If the problem still continues, do one of the following:
  • If you find the Related FAQ's at the end of the page, click it and check another solution.
  • If you don't find the Related FAQ's, please contact Brother Customer Service from "Contact Us".
  • If the printer status is Paused:
    Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
    Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
    If this does not solve the problem,
    Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
    Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
If you are using Windows Vista or Windows 7 please view here.
Trust this is helpful.
11/11/2021 10:14:23 PM • Brother MFC... • Answered on Nov 11, 2021
6answers
I'm trying to enter the
try holding in the button
9/25/2021 4:30:47 PM • Brother MFC... • Answered on Sep 25, 2021
3answers
Scan to email with MFC 7840W
you may try to install the CD of the brother MFC-7840W on your pc because it has the capability to scan your pc. Then one's you have installed it , it will create a shortcut on the desktop to scan your email document...
8/4/2021 10:15:41 PM • Brother MFC... • Answered on Aug 04, 2021
2answers
"brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
8/3/2021 7:34:22 AM • Brother MFC... • Answered on Aug 03, 2021
When I try to scan to file via Control Center 3, I receive a message that says:
I had this same irritating issue - after uninstalling and re-installing several times I decided to check the folders to see if there was any remaining Brother folders or files hanging around. First I went to the Windows Twain32 folder and removed the remaining folder in there - then I went to Programs files (both of them in Windows 7) and moved all Brother Folders AND Control Center folders to a created folder on the desktop (just in case) - reinstalled the software and it worked! Hope this helps someone because I tried all the other fixes and they did not work for me.
8/1/2021 7:17:56 AM • Brother MFC... • Answered on Aug 01, 2021
What is ip address and how can i change it
An IP address (Internet Protocol Address) is a logical address of a network adapter. The IP address is unique and identifies computers on a network. An IP address can be private, for use on a LAN, or public, for use on the Internet or other WAN.You cannot change the ip address, if you using static ip address.If it is dynamic ip address, you can change it easily by resetting the modem or switching it off and on.you can also use Proxy server or Hide ip address software to change the ip address.To check the ip address before and after changing, you can visit the site Ip-details.com. Here you can search IP,domain host and it also includes city, country, global latitude & longitude coordinates etc.
8/1/2021 7:17:47 AM • Brother MFC... • Answered on Aug 01, 2021
Black lines on the copies
Sir/Madam These types of lines are typically caused by dirt or tippex (correction fluid) on the scanner unit, or the corona wire is dirty. This problem is usually resolved by cleaning the scanner glass, scanner glass strip and white plastic bar with a soft lint-free cloth, or cleaning the corona wire. I suggest You Go to Official Brother Printer trouble Page For You Brother Printer Problem On Below Brother Printer forum URL Link: http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002900/000044/faq002944_000.html?reg=eu&c=eu_ot&lang=en&prod=mfc297c_eu I Hope You resolve Your Brother Printer Issue, OR In case You Need Online Assistance Then follow Us For ON: Brother Printer Support
11/16/2018 10:40:32 PM • Brother MFC... • Answered on Nov 16, 2018
4answers
Wireless printer problem
Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
9/24/2018 5:22:44 AM • Brother MFC... • Answered on Sep 24, 2018
My laptop does not recognize my printer in a
Reinstall the Printer on the laptop, using the WiFi connection choice when it comes up in the install wizard. The Driver will "Scan" the network and find the printer.
1/20/2018 2:56:33 PM • Brother MFC... • Answered on Jan 20, 2018
2answers
MFC-7840w keeps saying "toner life end"
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
1/2/2018 7:56:39 PM • Brother MFC... • Answered on Jan 02, 2018
0answers
3answers
Problem with our Brother mfc-7840w toner all over the page
since i finally figured this out I thought I would post this for anyone who has the HL-4040 CN printer - or one similar After seeing the hitting the buttons with the door open tricks for different models I tried anything that sounded like it had the same buttons my 4040 has... nothing on here worked so I just started hitting combinations of buttons with the door open - wow there are quite a few hidden menus there For the toner life reset menu: 1 Open the front cover of the printer 2 press and hold the cancel button 3 press the reprint button while still holding cancel - here is the reset menu - go to the appropriate cartridge on - the menu and reset it and you're done! FYI... Pressing the "Go" button and the up arrow gives you the parts life reset menu (drum, laser, fuser, etc.) I also did the electric tape over the windows - which worked before the reset - but I thought this fact would be helpful too. For anyone that is asking "what window?" I think it is the clear plastic opening on the sides of the cartridges where you can actually see the powder inside the cartridge - the color of the toner (magenta, yellow, or cyan). I didnt really know that for sure when I tried, but it made sense, and it worked. So I am fairly sure that is the "window" you should be trying to cover. you can go here for more update: https://www.microtonersupplies.com.au/toner/brother-toner-catridges
7/20/2017 6:58:19 PM • Brother MFC... • Answered on Jul 20, 2017
0answers
Email setup
Be the first to answer 5/29/2017 4:30:04 AM • Brother MFC... • Posted on May 29, 2017Be the first to answer
Drum Error on Brother MFC 7840W
Has two situations:
  1. The corona wire on the drum unit needs to be cleaned.Clean the corona wire on the drum unit.
  2. The drum unit has reached the end of its life. Replace the drum unit.
1/23/2017 3:05:09 PM • Brother MFC... • Answered on Jan 23, 2017
How do I reset the drum counter on the a Brother
open the front cover of machine ( where the cartridge is installed), then press the clear button, and then press 1 for yes for change drum question.
8/24/2016 11:53:12 PM • Brother MFC... • Answered on Aug 24, 2016
Brother MFC 7840W Printer Logo
607 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
problem our brother mfc 7840w toner all
  • Office Equipment & Supplies
