20 Most Recent Toshiba Portege M700-S7002 Tablet PC Questions & Answers
Cannot enter BIOS
When I am not sure what button to push to enter the BIOS, I start at ESC and quickly run my finger down the row of the F buttons. Don't push each button individually as that will take too long, but run your finger from left to right without stopping.
4/7/2014 12:50:49 PM • Toshiba Portege... • Answered on Apr 07, 2014
0answers
3answers
Finger print reader not working.....??????????????
@touchcoat
Try re-installing the following and reboot:
For Windows 7
1. Toshiba Fingerprint Utility (for Windows 7 (32/64) click here,
2. Upek Fingerprint Driver (for Windows 7 (32/64) click here,
For Windows Vista
1. Toshiba Fingerprint Utility here or here.
If above steps won't work, the issue is most likely a hardware issue. To make sure that it's not, I recommend trying to do a full system recovery (if you don't mind starting from scratch - turn the computer OFF, hold the 0 key then turn the computer ON).
If you still encounter the same issue, call Toshiba support and have the unit serviced at 1-800-457-7777 (for US) or 1-800-663-0778 (for Canada).
Good Luck.
11/12/2012 11:15:05 AM • Toshiba Portege... • Answered on Nov 12, 2012
My dvd drive won't open and the icon for optical
If the optical drive On/Off utility icon says OFF you cannot open the drive. You will have to turn it ON.
Point to the icon with the mouse cursor and right click. You will have the option to turn power to drive ON. Verify it by pressing Fn-TAB.
8/19/2011 1:47:33 PM • Toshiba Portege... • Answered on Aug 19, 2011
My cursor will not move without the mouse
The touchpad might have been disabled. try the Fn-F9 key combination. It toggles the touchpad ON or OFF.
8/19/2011 1:44:11 PM • Toshiba Portege... • Answered on Aug 19, 2011
I want to write pen
If you have Windows XP tablet PC Edition 2005 installed on it, you can use the Wacom Pen to enter text instesd of type it.
On Windows XP tablet PC Edition 2005, there is an Input panel Icon on the tray bar, usually to the left, close to the Start button.
Use the pen to click the Input Panel. When it opens showing you a black line on yellowish backround you can start using the pen as if it were on paper. Depending on the pen input setting it will insert automatically or waits for you to press the insert button.
However for the converted text to be inserted you need to have a text editing software open (Word Pad for example.)
If when you open the input panel you see a keyboard you can change that to handwriting (continuous line) or typing separate letters.
The computer can be taught to recognize your handwriting: You will need to practice. You might have to download and install the relevant ink recognition package for your language. Look for it on the Microsoft tablet PC page.
8/19/2011 1:41:16 PM • Toshiba Portege... • Answered on Aug 19, 2011
Hi I have a toshiba
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
8/18/2011 12:25:56 AM • Toshiba Portege... • Answered on Aug 18, 2011
I can't seem to find
try to open a virtual keyboard maybe one of your keys is stuck it should be in programs accessories
3/2/2011 2:18:29 AM • Toshiba Portege... • Answered on Mar 02, 2011
When booting, the system hangs
You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
should work.
As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
happened to me on my Vaio.
2/10/2011 1:10:13 AM • Toshiba Portege... • Answered on Feb 10, 2011
Where is the chapter 7
try going on the website www.toshiba.com fo user manual downloads .
7/28/2010 9:45:58 PM • Toshiba Portege... • Answered on Jul 28, 2010
Computer keeps slowing down like
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in safe mode.
Then go to start menu ->run type in "chkdsk /r" then press ok then restart computer then it fix errors on harddrive.
But if you are not able see windows logo and safe mode menu when you press F8 then open back panel of laptop if you have desktop then open cpu cover then reseat the RAM memory.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
2/2/2010 7:48:25 PM • Toshiba Portege... • Answered on Feb 02, 2010
I cant get any sound i have realtek high
try UAA Microsoft high Defenition Audio, at microsoft website
11/1/2009 11:44:52 AM • Toshiba Portege... • Answered on Nov 01, 2009
How do joy sticks operate
it is input device as mouse. it is use in to play game. we can operate game by arrow key in key bord. But joistick is as handle, we can roated it any direction so it hehps easy to play game. we can get it in usb and serial. thanks
6/13/2009 3:20:10 AM • Toshiba Portege... • Answered on Jun 13, 2009
Cannot boot up when the network cable is plug in
hello sir
your system have effected for viruses
get the fresh intallation and then your problem have solved
ok thanking you
4/29/2009 9:33:59 AM • Toshiba Portege... • Answered on Apr 29, 2009
Is Toshiba Protege E206 WIFI ready?
YES
6/18/2015 3:09:38 PM • Toshiba Portege... • Answered on Jun 18, 2015
How do I get Adobo Flash Player
Sorry, but flash player is no longer compatible with smartphones or tablets.
1/22/2015 10:38:51 PM • Toshiba Portege... • Answered on Jan 22, 2015
Toshiba Portege M700-S7002  Tablet PC Logo
26 questions posted
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Portege Toshiba
  • Portege Toshiba
Most Popular Question
finger print reader not
  • Tablets & eReaders
