20 Most Recent
Sony PS3 40GB Best Sellers Bundle Console Questions & Answers
Ps3 wont stay connected
It may be your Wifi signal. If signal is week it will keep booting you off. Check your connections make sure nothing is wrong with router.
Ps3 has no power
Well I think your house might have killed the PS3. I would recommend talking to an electrician about what happened.
You can try using a different TV and see what happens. However...
Unfortunately the PS3 is pretty much dead now. Hopefully its still under some kind of warranty or can still be returned (tell them it won't turn on). To replace the parts needed would require precise installment and should only be done by professionals.
Sorry for the death of the PS3.
Don't forget to rate :)
[email protected]
The network will be overloaded. Happens all the time. Or under maintenance
Hard drive for my ps3
Greetings, you have to format your hdd, if that doesnt work you have to buy a new hdd and put it on your ps3.to formatting your hdd you have to enter to ps3 service mode pressing the power button until you hear 3 bips.
How do i update my ps3
go to your settings then go to very top and hit update then udate your storage and internet if it says no applicable update available then your ps3 is up to date i think the last one released for now is the 4.31 version
It wont let me sign in ps3 network say's my e mail
Don't worry. There is a major issue
occurring right across the board at this very moment with the
PSN Network. Some consoles are not
synchronising properly due to an internal clock error and causing problems exactly like you describe. It is expected that Sony will soon have this resolved.
For a full breakdown please look at this
FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Turned ps3 on red light pressed on green light then amber then three beeps then flashing red light
Hello
there deanIf
you have the yellow light of death, this means the chips inside your
PS3 have lost connection to the Motherboard, there are several ways
to fix this problem and get back to gaming.Solution
Send
the console to Sony they will fix the problem if your in warranty, If
your not in warranty than it will cost you $150, the process will
take about 4-6 weeks and all saved data may be lost.Solution
Fixing
the problem with a PS3 repair guide Max cost $40 cheaper than repair
and replacement price.CONTACT
SONYFIND
A VERY GOOD PS3
REPAIR GUIDEHope
this helpsLet
me know if you need any help
How to use a european ps3 in united states
unfortuntely therewith that system are going to be a lot of features that you cannot use in the usa1) you will not be able to use some games with your ps3 the region code will have to be all2) if you do not have a US PSN account you cannot use PSN cards or game voucher codes3) you will not be able to see all items that are availible in the US on the PSN4) you will need a power adapter which will void your warranty (Sorry)
