20 Most Recent
Sony Wireless Controller for PS3 Questions & Answers
My ps3 will not recognize any wireless controllers
Did they connect before and now won't or are these new bluetooth set up connections? If new connections:
- In the XMB™ home menu, go to [Settings] > [Accessory Settings].
- Select the "Manage Bluetooth® Devices" option to register (or "pair") a Bluetooth-compatible device with the PS3.
I sill cant connect. just keeps on flashing and
Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
How do u get hulk skin in gta 4 ps3
A Hulk skin is not necessarily an option...More often than not, this will be what the PC gaming community calls a "Mod". It's basically a file that tells the game that "This is that and that is this". To get it, you're going to have to look into that.
Know how to change the wep key without knowing it
WirelessKeyView v1.70 recovers lost wireless network security keys/passwords (WEP/WPA) stored in your computer by the 'Wireless Zero Configuration' service of Windows XP or by the 'WLAN AutoConfig' service of Windows Vista, Windows 7, Windows 8, and Windows Server 2008. It allows you to easily save all keys to text/html/xml file, or copy a single key to the clipboard. You can also export your wireless keys into a file and import these keys into another computer.
http://www.nirsoft.net/utils/wireless_key.html
If you don't want to pay for a software, reset your router and set up a new key.
What pin code do I put in to pair ps3 controller to my ipad
Well usually it is the default bluetooth password if you haven't played with it, the default code being: '0000' or '1111'. That being said, unless you jailbroke your iPad in such a way that can accept the pairing, your controller will not work with the iPad.
Ps3 pad does not connect to the console
The problem you described seems to come from your ps3 game controller (pad). You can try a different one and see if it works.
If the game pad is charging, the ports are ok.
Hope it helps
How to use avalibile performance level
If you want to beat the game you have to continue to do missions until Karol calls you to his place to do business. He will then charge you $1 million dollars to go into business with him and you'll get any car you want free. Then you've basically beat the game and you can go race freely.
My controller is original dualshock3,...the stick
Have you tried using a different controller? Usually this is the problem, your PS3 controller's D-Pad is stuck on the left side or the responding piece beneath the D-Pad is being pressured down in some manner. I recommend trying a Different controller first before buying another PS3 ( get a cheap PS3 Arcade stick or something)
