20 Most Recent
MTX JackHammer JH600 Car Audio Amplifier Questions & Answers
Amp going into safe mode acts like its not getting enof power, power and ground are both 4 gage and hooked up corectly
Check the speaker wireing that it is not off somewhere ,or pinch.End shorting out. If all that is okay. It is not wired up properly to the sub or what ever speakers you have hooked up to it, Or you don,t have it set up (Poperly) They do not go into the protect mode For nothing,Unless you are trying to wire up your sub or (Speakers) To lower ohms then what it is stable for.If that is the case your lucky that it hasn,t went up in smoke yet,End that is not covered buy any manufacturs Warrenty,
My MTX JH600 works intermittently.
One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
