20 Most Recent Samsung LN46A550 LCD TV Questions & Answers
2answers
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
3/27/2019 1:06:01 PM • Samsung LN46A550... • Answered on Mar 27, 2019
At initial startup (don't turn off all day) once tv turns on the screen has a heavy vertices green or red overlay...tv will turn itself off then come back on by Itzel's..may do this twice or s
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
6/17/2017 8:30:40 AM • Samsung LN46A550... • Answered on Jun 17, 2017
2answers
When the TV is turned on after being off over
Most likely the main mother board of the TV is the problem. The main board controls everything inside the TV from audio to video and TV program software. There maybe loose connection to the main board or the board is starting to go bad.
4/4/2015 9:24:28 AM • Samsung LN46A550... • Answered on Apr 04, 2015
Factory reset samsung
TV OFF _MUTE+182+POWER on remote control. or 24972225-crrnmqnqs2ucyeabzojnkgwz-1-0.jpg
1/27/2015 11:24:09 PM • Samsung LN46A550... • Answered on Jan 27, 2015
Program BN5900673A to Samsung
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
8/15/2014 12:49:03 PM • Samsung LN46A550... • Answered on Aug 15, 2014
What can i do with the usb on the side of my
in your customer instruction book it give the details or go to samsung.com. the main use for the usb connector is for the using a flash drive to look at pictures you download from computer from a digital camera or other device,to the flash drive or memory stick if you will.
4/11/2014 4:11:24 PM • Samsung LN46A550... • Answered on Apr 11, 2014
0answers
0answers
Samsung le32r7 tv picture light levels v low
Reverts eventually means there is some looseness some where. Please check connectors and cables between power supply- TCON, TCON- Panel and main board-TCON. If you cant do it show it to some qualified technician.
12/25/2013 2:41:46 PM • Samsung LN46A550... • Answered on Dec 25, 2013
Samsung 40" LCD Right Half of Screen Distorted / Pixelated
I think you are screwed. When the price to repair exceeds 25% of the unit cost I get new up-graded items. New warranty for better items
5/9/2013 7:43:13 AM • Samsung LN46A550... • Answered on May 09, 2013
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
2/19/2013 1:28:07 AM • Samsung LN46A550... • Answered on Feb 19, 2013
Samsung LCD TV 46 inch LN46A550 colors are all messed up.
My solution to that pixelation color problem was replacement of the flat wire connected to the Tuner board and video data board,must be new and original replacement part. I clean the terminals(don't brush just spray on)with electronic contact cleaner,let it dry or blow dry with hair dryer to vaporize left over liquid on both boards.Reason these flat wire problem is due to environmental(moisture)corrosion and breakage of the folded parts of the wire. I tested the replaced part and found breaks or cut ,we call it in electronic term"open connection".
1/29/2013 12:59:33 AM • Samsung LN46A550... • Answered on Jan 29, 2013
2answers
Hi A couple of weeks ago,
It will be good to have a ccheck within and see if there is any visible indications of failure. check if power capacitors have bulged out if so replacce.
But I thnk the possible fault can be soldering faults/problems in the drive/converrgence circuits.
Dry soldering is the greatest enemy and I think that the parts exposed to heat / cool in due course of time have the drying of the solder.
So use a good iron carefuly not to bridge circuits but to solder suspeccted joints. IC pins and connector joints. use good quality solder with good lighting .
comment and credit if this advice helps.
1/29/2013 12:49:59 AM • Samsung LN46A550... • Answered on Jan 29, 2013
Samsung LN46A550 LCD TV Logo
65 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
half screen isa dark left side
  • Televison & Video
