20 Most Recent Sony Bravia KDL-46V4100 46 in. LCD HDTV Questions & Answers
My Sony Bravia tv screen
If you haven't done so already, check that the cable between your tv and digital cable box(probably HDMI) is secure at both ends. If it is, try a different cable and/or different port on your tv if you have more than one. If the issue is still there after you've tried these options it's most likely an issue with either the digital box or tv. I would contact manufacturer at this stage for advise and possible replacement of tv or box if they are under warranty.
Hope this helps.
12/30/2017 9:02:46 AM • Sony Bravia... • Answered on Dec 30, 2017
0answers
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
6/7/2017 8:49:19 PM • Sony Bravia... • Answered on Jun 07, 2017
Sony kdl-46v4100 red light blinks 6 times please help
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
11/21/2016 1:45:54 PM • Sony Bravia... • Answered on Nov 21, 2016
Why is my tv beeping
Take a look at this: https://www.youtube.com/watch?v=0KGysXbxnaU
10/11/2016 11:52:49 PM • Sony Bravia... • Answered on Oct 11, 2016
2answers
How do I reset my TV?
Hi please open the MANU & then go setting where the factory rest is available so select the factory reset thanks
5/20/2016 7:46:44 AM • Sony Bravia... • Answered on May 20, 2016
Wall mounted the tv but have thrown out the stand how much for replacement stand.thank you
Hi Greg, you can get an idea by looking on Ebay or Amazon.....CHEERS..
5/12/2016 1:04:48 PM • Sony Bravia... • Answered on May 12, 2016
When I plug this tv in, a red light blinks 2 times and stops, and blinks another two times and stops and keeps doing it over and over again....
THE MAIN POWER BOARD IS DEFECTIVE SOME VOLTAGES ARE MISSING SO THATS WHY SET BLINK TWO TIMES PLEASE REPLACE POWER BOARD
5/7/2016 9:40:46 AM • Sony Bravia... • Answered on May 07, 2016
How do I get Netflix on my Sony tv
You used to be able to stream Netflix on this model with the Bravia Internet Video feature. (BIV) Unfortunately this feature is no longer supported. In order to get your Netflix now, you will need a Roku box or a Netflix thumb drive (fire stick). I hope this helps.
5/6/2016 12:29:43 PM • Sony Bravia... • Answered on May 06, 2016
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
4/10/2016 10:43:38 AM • Sony Bravia... • Answered on Apr 10, 2016
Why can't it be turned on again after turning off?
More information please
What kind of TV
How old is the TV
Did you try unplugging the TV and letting it sit for about five or 10 minutes before power cycling it
Does it have a remote are there fresh batteries in the remote I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
4/3/2016 4:43:05 PM • Sony Bravia... • Answered on Apr 03, 2016
0answers
Can't connect to netflix
3/21/2016 8:45:44 AM • Sony Bravia... • Answered on Mar 21, 2016
The tv keeps turning itself off. The red light is blinking after the tv turns off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1/20/2016 10:49:05 AM • Sony Bravia... • Answered on Jan 20, 2016
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
374 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
39 t connect netflix
  • Televison & Video
