20 Most Recent
Sylvania LC420SS8 LCD TV Questions & Answers
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
5/11/2017 5:52:09 AM •
Sylvania...
Answered
on May 11, 2017
We have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
9/25/2014 7:51:01 PM •
Sylvania...
Answered
on Sep 25, 2014
Green light flashes back red
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
9/22/2014 6:15:46 AM •
Sylvania...
Answered
on Sep 22, 2014
Code for a NH000UD
0029,0026,0039,0035,0033.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list
& set-up procedure to many popular brand remote controls.
Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
8/25/2014 4:03:52 PM •
Sylvania...
Answered
on Aug 25, 2014
