20 Most Recent
Sharp MX-2300N Color Copier Questions & Answers
Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Maintenance required: code dk
Ok so the DK code means that the Black drum counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 07
Then you can select what you want to clear so the bk drum unit
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Finisher trouble, F1-00
F1-00 lost communication with the finisher, check the connection between the copier and the finisher. Shut the machine off, reset the connector then restart the machine.
Error Code L4-31
The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. The fan is one of the two located over the right side door.
Cannot change network settings - Admin password unknown
Got in with random trialling passwords for the Administrator... finally found the default password for Administrator on the Sharp MX2300N was "admin". Should have known...
Got in, set up the IP's and away we go again. Did not have to go in with any maintenance mode or re-setting the whole system.
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem. I’m happy to help further over the phone at
https://www.6ya.com/expert/ethan_e84416e0b13809d2
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
